exhaust size..need help
Old Jun 26, 2004 | 10:14 PM
Godzilla's Avatar
What is the oem exhaust pipe/muffler size for a 2nd gen (92) 4runner. Is it 2.0 or 2.25????
Old Jun 26, 2004 | 10:20 PM
bulldog-yota's Avatar
Godzilla's exhaust was measured in feet not inches
Sorry just had to have a crack at it, your screen name leaves a question like that wide open for abuse.
Can't help you, but at least you get a bump!!
Old Jun 26, 2004 | 10:24 PM
Godzilla's Avatar
sorry not to clarify..the diameter of the pipe is what im looking for,,in inches
Old Jun 26, 2004 | 10:31 PM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
Is it a 3.0 or a 2.4L? Makes a difference. I'm guessing 3.0 since you started at 2".... 2" is oem or at least right around where it should be. You can go 2.5" on a 3.0 without running in to backpressure issues. Someone with a 3vze will hopefully chime in.
Old Jun 26, 2004 | 10:34 PM
Godzilla's Avatar
if the tailpipe tubing is 2.0 inches, do i get a muffler that is 2.25 to fit? or just get the 2.0 muffler..man i dont know jack about exhaust
Old Jun 26, 2004 | 10:36 PM
Godzilla's Avatar
its the 3.0L. is the 2.25 the way to go for the muffler, and will this still fit up with the stock cat?
Old Jun 26, 2004 | 10:40 PM
flecker's Avatar
Hopefully your welding the muffler in right? If you clamp it they never seem to seal right IMO. Just take a chunk of your pipe with you and test fit it in the store/ shop.
Edit: most mufflers are set up to slide over the pipe for easy fit up and welding.
Old Jun 26, 2004 | 11:04 PM
Godzilla's Avatar
in the magnaflow catalog , for the runner they indicated the 2 inch muffler/pipe..everywhere i turn though its all about 2.25 for power and etc... which should i get?? so so confused
Old Jun 27, 2004 | 07:24 AM
flecker's Avatar
Any little bit on the 3.0 helps
Steven.m.paulk
Jun 7, 2020 10:45 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
