E-brake????
E-brake????
Does any one else’s E-brake light randomly come on when it is cold outside. It just got kind of cold here and this morning my e-brake light come on like 10 times on the way to school. The brake isn’t activated at all and I pushed it in just to make sure. The brake isn’t sticking either. Truck rolls find when just in drive…..any ideas? 98 taco.
A couple of winters ago, my e-brake light would come on when it was cold out, but would go off once the engine warmed up. Turns out that was just the first sign of my alternator failing. While you're checking the brake fluid, see how many volts you're getting out of your cold alternator.
how many volts does it put out? Fluid is good, not close to the bottom line.
If it's below the top line, then you'll be in a better spot if you top it off.
priest16
15
Aug 6, 2015 07:43 AM
