drum brake help asap!!
Old Feb 16, 2014 | 03:37 PM
2002 taco's Avatar
Took off my rear brake drums, and drivers side shoe are not contacting drum at all. How do I correctly adjust them out?
Old Feb 16, 2014 | 03:42 PM
2002 taco's Avatar
Sorry, 2002 Tacoma 3.4l 4wd
Old Feb 16, 2014 | 08:18 PM
tantacoma's Avatar
rotate the adjusting wheel, until its slightly difficult to put the drum on.
Old Feb 17, 2014 | 11:53 AM
Nelsonmd's Avatar
The adjusting wheel is accessed from the back side of the hub, through the little slot plugged with rubber. Use a flat screwdriver and turn it until the brakes are just grabbing the drum.
Old Feb 17, 2014 | 12:34 PM
2002 taco's Avatar
Thanks, I think I have them adjusted good now. I don't think the drivers side had been contacting the drum for some time now.
Old Feb 17, 2014 | 12:35 PM
2002 taco's Avatar
Now I just need to swap the front to the 231mm tundras because they are almost ready to be replaced.
Old Feb 17, 2014 | 12:49 PM
ksti's Avatar
Does your taco have rear self adj. brakes?
If so your probably going to have the same problem down the road.
Star wheel could be gumed up causing it not to adjust when pulling on e-brake.
Just my two cents worth.
Old Feb 17, 2014 | 12:54 PM
2002 taco's Avatar
It actually wasn't too bad, but I cleaned it up more and I need to do the self adjust with ebrake some more today.
Old Feb 18, 2014 | 06:50 AM
tantacoma's Avatar
When I had a similar experience, I over-adjusted the shoes a bit. On my first drive down the road, the drums got real hot. I could smell them when I got out of the truck.
So, check them for heat occasionally (simply by touching the wheels) , to make sure the shoes aren't too close to the drums.
Old Feb 18, 2014 | 04:16 PM
wyoming9's Avatar
Red face
If your shoes are not adjusted enough it will take forever trying to get them correct with the emergency brake.
Old Feb 18, 2014 | 05:40 PM
2002 taco's Avatar
Thank you everyone.
old87yota
Sep 9, 2015 12:39 PM
SharpStick
Aug 29, 2015 12:59 PM
digdug40
Aug 28, 2015 02:24 PM
4x422r
Aug 18, 2015 05:33 AM
CanRunner
Jul 20, 2015 01:29 PM
