Driveway poser shots
Originally posted by 44Runner
It is definately within an inch of the width of the rear I think. The whole thing has a very nice stance to it with the 15x10 rockcrawlers with 3.5" backspacing. Probably at least 6" wider than before and about 3" or so taller...
I can't wait either. It returns to DD duty next week so I have to get things ironed out quickly...
Very nice indeed...any complications with the front drive shaft? I notice it isn't installed yet and that is the one thing that I am worried about before I even think about the swap. I'm going to read up on your site before battering you with questions, but one more thing, how did you get the rear up that high? 3.5inch lift springs w/spacers? I'm thinking if the rear is raised somewhat easily, then using the Taco front trailmaster lift along with however u did the rear would make for a easy'er 6 or so inch lift.
Overall great job man!
Re: Golly
Originally posted by White SR5
Sheesh... read through your website and looked at most of the pics. You did a hell of a lot of work! How much time would you estimate you put in? I'd be interested to find out. Let us know how it goes after the 1st drive!
Zach
Zach
It has been a blast for the most part. There have been times where I just wanted to freakin cry I was so frustrated with things not coming together and stuff. I ran into a TON of problems during this project just getting ahold of stuff that should normally be very easy to get. Just terrible luck around every corner.
I used a ton of vendors during this project and only a select few gave me no trouble at all. Tim at ShakerBuilt definately pulled my butt out of the fire when he came through with my drag link in record time when another vendor dropped the ball on it. Not only was his link cheaper, but it was better. Tim is definately the man to go to for all your steering linkage needs as I can speak to the quality of those directly.
Mike from xtreme-offroad was another wonderful vending experience. Nothing special, but he did his job. I ordered something from him and he was wonderful to deal with and he got my entire order to me in a decent time, no BS. While that might seem to some fairly basic to some, that never happened during this project for me minus a couple vendors and he was one of them.
Dave at Cornfed suspension also did his job and got his stuff to me with no BS. While they didn't fit, that wasn't his fault as they had never been tested on my coils before and I was able to get them fixed by a friend so no worries.
Notice all these guys are probably the smallest companies i dealt with during the whole thing. I think that says something to the level of commitment of these small guys to their customers.
Spacers:
http://www.4x4wire.com/cgi-bin/ultim...;f=13;t=016690
#27
You might want to call Marlin and have them record your info on the MC09 in his book. They did not record your unit.
It goes from #13 (Ronn Erickson) to #16, which is me. I assume you are either #14 or #15. It also looks like they did not stamp all the info on your unit like they did on mine. Who cares, but kinda looks like yours was indeed rushed out the door incomplete, which does not really surprise me.
Looks like they forgot to give you the low profile drain plugs as well. That place is really disorganized.
#28
Mine is #15, there is an 015 stamped on the unit and I believe some other stuff. What info is supposed to be stamped on there? I only took note of the #15 cause that was all that mattered to me, I couldn't even tell you what else is on there other than I know there is some other stuff.
It would probably scare me to see what that shop actually looks like. I am very happy with the unit in general, just wasn't happy with the unbelievable hassle I went through to get all the parts for it.
Here is the thread:
http://www.4x4wire.com/ubb/ultimateb...=010543#000000
What did you do with your e-brake Steve and what gears did you end up using in the front case?
#29
Front case on mine has 4.7 Japanese made gears. So everything "inside" the front case is new.
They made me 2 custom shift levers, so the brake handle & 1 cup holder stayed intact. All I lost was 1-cup holder.
I have pics of the place. You had better believe they will scare you. Basically it's a Toyota drive train junkyard.
#30
Its funny, I thought of fabbing something to move the back shift over to the left but i thought it would be kind of a PITA. Turns out my "easier" way, was probably just as hard if not harder. Live and learn i guess. I made end up going with something different in the long run but for now it works and works well. Just no cup holder
#32
I certailny looks like it could take you to some "out of the way" places.
Do you have a guess of what you have spent to make the whole thing happen. Of course that would mean the hardware, since you did all of the work yourself. Could you imagine what you would have spent in labor???
#33
If you JUST count the big dollar items like the crawler, the lockers, and the tires, you are looking at close to 4 grand.
Then add the 2 something grand talked about earlier and then the stuff for the rear, I am probably sitting over 6 grand. No wonder it took me 2 years to pull this off...
#34
Steve I want to see pics!!!
#35
JookUpVandetti
Sep 30, 2015 08:58 AM
