Diagnostic Issue with my 4Runner - Weird Problem - Any help is appreciated
Old 10-23-2011, 07:23 PM
car-whore's Avatar
Well, I finally got around to changing out my leaking valve covers on my 00' 4runner. While torquing down the bolts, my friend cracked my valve cover so I actually had to do the job twice....
After putting everything back together, I'm having some problems with my truck which seem to be emissions related. Basically, my 4runner runs absolutely perfect up to about 60mph. At 60mph, the engine starts to vibrate and the faster you go, the more it does it.
I was initially throwing 2 codes which were both P0171 - System too lean. I replaced the MAF and I'm now throwing only one P0171 code. I was pretty diligent about making sure all the vacuum lines were reinstalled and I checked to see if I missed any lines but didnt see anything.
I really need to get this thing fixed and I'd really appreciate it if somebody who has had experience with this issue can chime in and give me some help.
Thanks guys....Michael
Old 10-23-2011, 07:33 PM
totally a bro
Staff
vital22re's Avatar
how were the gaskets for the intake?
Old 10-23-2011, 07:37 PM
car-whore's Avatar
They didn't look bad. The vehicle has 263k miles. They're metal and I figured I would reuse them. I was kind of thinking that it might be a good idea to change them....what do you think?
Old 10-23-2011, 07:38 PM
car-whore's Avatar
I'm willing to try anything at this point, I can't find any spare hoses...everything looks good...just doesn't run right
Old 10-23-2011, 07:53 PM
totally a bro
Staff
vital22re's Avatar
I had the same code during last winter but it went away after trying 2 different MAF's. Check your air intake for cracks. I will be replacing all of my intake gaskets before it gets too cold out.
Old 10-23-2011, 08:02 PM
car-whore's Avatar
I just replaced the MAF with a factory toyota part....seems to be working like it should.
I've ordered a K and N intake system, I'm tired of the stock intake. It just annoys me looking at it because it just seems so pointless.
I'm going to install the new air intake and then see where I stand. If it doesn't fix the problem, I'm going to get new intake gaskets, pull everything apart (again), replace the gaskets, and make sure I'm not missing anything.
Old 10-23-2011, 08:45 PM
oddjob1370's Avatar
I was told that intake gaskets need to be changed out everytime you take the intake manifold apart. Something about it not sealing correctly a second time.
Old 10-23-2011, 09:40 PM
totally a bro
Staff
vital22re's Avatar
return the k&n intake. Buy a AFE dry flow filter and do the ISR mod. The oiled filters will only gum up your MAF sensor
Old 10-23-2011, 10:51 PM
4x4climber's Avatar
true dat. go AFE! ^^^ double/triple check every vacuum line and every plug before buying more parts. And... yes, your intake gaskets may be a bit of a problem. If you did not replace them that could be your whole problem. Always replace gaskets you remove. Keeps you from doing it twice.
Old 10-24-2011, 06:37 AM
car-whore's Avatar
Thanks for all the help guys!
I will return the K&N and go the AFE route.
Any suggestions on which intake manifold gasket kit to go with and where to find the best deal? I didn't realize they were close to $100 for an aftermarket gasket set.....
Old 10-24-2011, 06:39 AM
car-whore's Avatar
Also, if someone knows what the intake manifold bolts should be torqued to, that would be helpful information. I'm going to make sure absolutely everything is right this time around. Thanks!
Old 10-24-2011, 03:39 PM
rworegon's Avatar
5Vz-fe engine?
Does page EG-59, step 17 help you out?
http://www.ncttora.com/fsm/1996/SIL/...c5v/torspe.pdf
Additional torque values:
Old 10-25-2011, 05:42 AM
car-whore's Avatar
Originally Posted by rworegon
5Vz-fe engine?
Thanks for the info.
Update: I changed out the upper and lower plenum gaskets and I'm still having the same problem. Vehicle is running idling rough and still has the vibration issue. My intuition tells me it has something to do with the ignition system. I recently changed out the plugs and wires but have never changed out any of the coil packs. Is this a logical next step? Again, any help is appreciated!
Does anyone have the link to the service manual handy that they can share as well...........
JF9243176
10-08-2017 04:21 AM
noahstancik
07-10-2015 11:18 AM
WI Girl
06-25-2015 03:45 AM
JF9243176
06-24-2015 04:53 AM
atticus
7
05-26-2002 12:14 PM
Quick Reply: Diagnostic Issue with my 4Runner - Weird Problem - Any help is appreciated
