deckplate mod
Old Jul 15, 2002 | 11:23 AM
  #41
dlotoy4runner's Avatar
Originally posted by jalaber
dlotoy4runner, keep us updated and let us know if the mod finally works! Take some pics also to make it even more easier for others.
Okay. Last question
Which end do I ground? The coming from the engine or the one going to the main DRL switch?
Old Jul 15, 2002 | 11:26 AM
  #42
ckonarske's Avatar
Originally posted by dlotoy4runner
Okay. Last question
Ground the wire that runs up into the wire loom, not the one that runs into the connector.
Old Jul 15, 2002 | 11:30 AM
  #43
Thats the one I grounded and it still didn't work. And once I reconnected all the wires. It worked back to factory specifications.
Im so frustrated
Old Jul 15, 2002 | 11:32 AM
  #44
ckonarske's Avatar
Im so frustrated
Did you also do the other part of the mod on JA's page?
Old Jul 15, 2002 | 11:38 AM
  #45
I performed all the steps on JA's site and used your pics as a guide.
1. I bent the top prong up and out
2. Connected the 16 gauge wire with a female disconnect to bent relay prong and then the remaining end to the left side of the tail light fuse
3. Cut the green wire with black stripe and grounded the end coming from the engine to the fuse bolt
Still nothing but when I reconnected the wire to make it back to factory the fog lights worked. What if I used a 10 gauge wire?
Danny
Old Jul 15, 2002 | 11:44 AM
  #46
ckonarske's Avatar
Sounds right. Any wire, #16 and up should work.
The only other thing I can think of is a bad crimp, or some other reason for a bad connection.
Old Jul 15, 2002 | 11:51 AM
  #47
ckonarske's Avatar
I don't see what else could be wrong if you have followed the install instructions ( and it sounds like you have). Do you have anyone who could do a circuit test and/or a continuity check for you?
Old Jul 17, 2002 | 11:28 AM
  #48
Guys,
I'm giving up on the idea of the fog light mod. That prong is not looking so good and at $50 a pop, Id rather use that money towards some Husky floor mats for the front. I'm just glad I still can turn on my fog lights.
Dang I wish I had the fog lights working with the parking lights. ARGHHHHHHHHHHH
Old Jul 17, 2002 | 11:33 AM
  #49
ckonarske's Avatar
Guys,
Switch the relay with another identical relay in the relay panel. That will allow you to bend and re-bend a couple more times without breaking anything.
It's driving me nuts that I can't figure out what's going wrong on your mod!
Old Jul 17, 2002 | 11:42 AM
  #50
ckonarske's Avatar
FWIW, for anyone trying any of the fog light mods, there are five identical relays in that relay panel, at least in the 2002 They can be swapped with each other if you feel like the relay you're working with won't tolerate any more bending.
Danny, did you get my email?
Old Jul 17, 2002 | 11:56 AM
  #51
ME TOO... Maybe I'll wait a few weeks again to do it. I plan on the
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
