Comparing RPMs & MPH based on Gear Choice
Old Oct 2, 2007 | 10:17 AM
Rock Slide's Avatar
Edit:
Aaron made a good point about true speed vs what the speedometer reads. Once you increase your tire size, your speedometer is no longer 100% accurate. Once you regear, it brings the speedo closely back to being accurate, but it is still not 100%. It does not bring it back to being as accurate as it was with stock tires and stock gearing.
Since the chart I had posted was not 100% accurate, I've moved it back to my original post in RunnerUp's thread:
https://www.yotatech.com/forums/f2/f...locker-125949/
I had calculated rpms at specific speeds based on what the speedometer needle read. However, with larger tires are installed, the speedometer was not 100% accurate. Like I stated earlier, even when a vehicle has been regeared, it is still not as accurate as it was when the vehicle was completely stock.
Therefore, unless you have installed a True Speed calibrator to correct you speedometer or have measured your mphs using a GPS, then the speedometer will not read 100% accurate. So to keep the confusion down for anyone who searches for this thread later, I have moved it to the thread I linked above.
stormin94, I have also added you numbers to the linked thread too. Thanks.
Old Oct 2, 2007 | 06:08 PM
stormin94's Avatar
1994 4Runner 5-Speed 4.30 gears 4x4 31-10.50-15 tires(stock was 225)
60=2500
65=2700
70=near 3000
80=near 3600
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
