Cleaned engine, now it idles badly
Old Jun 10, 2006 | 08:59 PM
getitdone's Avatar
I wouldn't change the plugs and not the wires, or visa versa.
Old Jun 10, 2006 | 09:00 PM
getitdone's Avatar
Originally Posted by msw0085
No cap or rotor.. its a direct ignition system on these motors
:pat: Well I don't have one so...
Old Jun 10, 2006 | 09:01 PM
msw0085's Avatar
haha i wont tell anyone. Sounds like i need to place an order with Toy of Dallas
Old Jun 10, 2006 | 09:03 PM
Elton's Avatar
i got new ngk wires for $37 shipped lot better than the $68 dollars the dealer wanted
Old Jun 10, 2006 | 09:04 PM
  #25
msw0085's Avatar
linky?
  #26
ebelen1's Avatar
Happened to me when I first got the truck and had it detailed. The idiots (not saying you did the same) blasted the motor w/ water. Water got into the spark plug area and the truck had very similar symptoms to you (e.g., stumbling, smelling, etc.). Brought it back to the detail shop and they kept saying the water would dry up. They even tried blowing compressed air into the spark plug area to help dry the water.
Well after a few days of this crap and finally a CEL, I brought it to my buddy. He pulled the plugs and replaced all of them as they were corroded from the water. It's run great since. Maybe this is all you have to do w/ some new wires as it looks like this hasn't ever been done.
Old Jun 10, 2006 | 09:05 PM
  #27
getitdone's Avatar
Damn. Matt, Napa has ngk's. I can even get them for you at cost price as well as anything else.
Old Jun 10, 2006 | 09:08 PM
  #28
Elton's Avatar
linky?
ngks $27
http://www.sparkplugs.com/more_info....72574&pid=3716
or denso for $37 http://www.sparkplugs.com/more_info....2574&pid=19513
Old Jun 11, 2006 | 03:31 PM
  #29
msw0085's Avatar
Got the codes read at an auto zone.. it came back clean. Tomorrow I'm gonna replace the wires and plugs and fuel filter. I drove it to work and back today and it ran like a champ.. no stumbling or struggling..
I keep getting curiouser and curiouser..
Old Jun 12, 2006 | 08:20 PM
  #30
msw0085's Avatar
Borg Warner wires, NGK plugs and a new fuel filter = runs perfectly.
Thanks Chris.
Old Jun 13, 2006 | 07:44 AM
  #31
quattro's Avatar
Check for water incursion in critical sensor connectors. Like pull each connector off and ensure it's dry with compressed or canned-air. Then put some contact cleaner on and re-insert. I would make sure to hit: Throttle Position (TPS), Mass Air (MAF), each of the coil pack connectors and cam position at minimum.
This is a bit of a long-shot since there were no codes bubbled up - but it's an easy thing to double check. Very common problem on Audi V8's (I know German vs. Japanese...) I've been advised by Toyota certified folks in Europe to simply let the engine be dirty. Clean the compartment with water, sponges/brushes whatever but let the engine do it's thing.
Best of luck, I hope you find it.
bigjstang
Jun 2, 2025 03:56 PM
Whatever123
Sep 30, 2015 12:12 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
