Chevy V8 Engine swap
Old Apr 3, 2005 | 12:52 PM
psfccsmfwfhitt's Avatar
Does anyone know if there is a kit or something that I could buy, like all of the fabricated parts for installation. I want to swap the 3.0 from a blown 4Runner with a Chevy 5.7. I can weld I am a [censored] fabricater. Also... what is the 6-speed tranny in the t/a's and cameros? I am going manual on this one.
Old Apr 3, 2005 | 01:03 PM
sorry, wrong section. please move
Old Apr 3, 2005 | 01:15 PM
DudeBud's Avatar
check here http://www.advanceadapters.com/newidea.html should have what you need
Old Apr 3, 2005 | 01:26 PM
Truck engine bay = 4runner engine bay? I was looking at them a while back but was not sure. I think it is, last time I looked they appeared to be about the same.
PS
Old Apr 3, 2005 | 01:29 PM
DudeBud's Avatar
PS
yep pretty much the same
Old Apr 3, 2005 | 01:48 PM
Mud_Lovin_Yota's Avatar
Advanced Adaptors make the motor mounts, radiator, headers and everything else you need. The tranny is a T-56 six speed. It will take a lot of modding to get that tranny to fit in I bet. The T-56 swap is common in S-10s. I swaped one in to my S-10 Blazer and it was a BIG job.
Old Apr 3, 2005 | 03:29 PM
What would be the most simple manual tranny to fit in? Like I said I'm not to good at this but want to get better, I just don't want to get over my head then give up... waist of money, rig, time, ect.
Thanks!
PS
Old Apr 3, 2005 | 04:07 PM
Swap in TH-700R4. Its a auto tranny, but it will be a lot easier to swap in.
Old Apr 3, 2005 | 06:06 PM
kyle_22r's Avatar
autos suck, put an SM465 behind it.
Old Apr 4, 2005 | 12:30 PM
Flamedx4's Avatar
Simplest? Keep the trans you have.
Otherwise look to see what adapters they have. If it ain't listed, it won't be simple.
Old Apr 4, 2005 | 04:37 PM
toy283's Avatar
What year/generation 4Runner are you talking about? Because you are swapping out a 3.0, I'm assuming you have IFS (if it's 4WD). Is it 4WD though? If so, swapping a T56 would require finding a suitable GM transfer case and adapter since there aren't any for Toyota t-cases. The best manual tranny out there for the swap would be an NP4500 from a 1-ton Chevrolet truck: Granny low, overdrive and available adapters to Toyota transfer cases. Also, there isn't an all-inclusive "kit" avaiable out there, just a conglomeration of individual parts. This is because there are so many different variables in engine swaps and abilities. If you're a good welder, it is far easier & cheaper to fabricate your own motor mounts than to spend $120+ for off-the-shelf ones. Same applies to other custom items like crossmembers.
4.34runner88
Feb 7, 2016 02:24 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
superdogg2014
Domestic Swaps
Sep 19, 2015 09:13 AM
