Check Engine Light... I have Had Enough...
Old Feb 28, 2007 | 03:13 AM
  #141
MTL_4runner's Avatar
Originally Posted by partyman66
Hey YotaFun...
Did replacing your 02 sensor get rid of the code permanantly for you?
My rig threw a p0136 CEL tonight and I need to start trying to figure it out, but it's freakin snowing out now, so I can't really go out and do anything at the moment.
With the P0136 code you need to check for exhaust leaks (ie leaks upstream of the rear O2 sensor) and fix those first. If you have no leaks and still get the same code, then more than likely it is the O2 sensor that is bad and a new sensor should clear the code for good.
Old Feb 28, 2007 | 06:53 PM
  #142
YotaFun's Avatar
The o2 Sensor did permanently get rid of the light,
but I for the life of me can't recall if I have the same code as you.
And my eyes is going cause i can't seem to read it any where in my posts....
Old Feb 28, 2007 | 09:42 PM
  #143
partyman66's Avatar
Originally Posted by YotaFun
Got the code pulled about 15 min ago...
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
So yeah thats my prob...
Now I must look into fixing it...
Looks like you had the same code.
I've been doing a ton of short drives lately(about 4 or 5 miles each way) and almost no highway drives. I was thinking that as a result, it's a possibility that I had a lot of carbon building up on my O2 sensor due to all the warmup cycles without really ever hitting top temp for an extended period of time.... so I threw a container of Prestone Fuel System cleaner in my tank and filled up last night, drove about 20 miles down the highway pretty hard and then reset the CEL. It hasn't come back on yet(been about 40 miles since I reset it), so we'll see what happens. I suspect it will come back on sooner or later at which point I'll probably pull my 2nd 02 sensor and try cleaning it with electric cleaner and see if that does anything... and if not, replace it. I also cleaned my MAF sensor tonight and the throttle body and throttle plate just for peace of mind.
There are no exhaust leaks... although I'm expecting the exhaust manifold to crack within the next 2 years or so, since it seems they all do on 3RZ's at around mine's age.
How much did they charge you for the replacement rear 02 sensor? The guy at Autozone told me it was $295 from them, so there's no way in hell I'd do that since the most expensive one I've seen online for our trucks was like $160.
Old Mar 1, 2007 | 06:02 AM
  #144
Get one from Gadget over at URD:
http://www.urdusa.com/product_info.p...s_id=430006000
Phil / Jacque over at Toyota of Dallas
www.trdparts4u.com
Old Mar 1, 2007 | 06:45 AM
  #145
YotaFun's Avatar
Advanced Auto Wanted $131, I payed it because I needed the part because i was about to go on a trip and the sensor needed to be driven in so that when i went back for my inspection it would be functioning.
But URD is a great price for it.
Old Mar 1, 2007 | 09:27 AM
  #146
partyman66's Avatar
Alright cool... thanks for the quick feedback. I'm not too worried about spending 80 or 90 bucks to replace the 02 sensor if it'll fix it, but spending $300+ on the part only to find out that it doesn't fix the issue would make me want to Chuck Norris-Roundhouse Kick a mexican baby several times in the face with a steel toed boot. I probably listen to too much Dane cook.
Old Mar 1, 2007 | 11:25 AM
  #147
YotaFun's Avatar
When you order just make sure you order the REAR o2 sensor, the front and rear have diffrent hook ups and are not interchangable, Just lookin out
Good luck wiht the fix
Old Mar 7, 2007 | 09:10 AM
  #148
Joe's Toy's Avatar
Originally Posted by Dug
Actually I get something sort of similar. No symptoms or anything, except that the check engine light only comes on a couple miles into the first drive after I unplug the battery and then switches itself off 1 or 2 days later. It's really weird but since there aren't any symptoms, I haven't really done anything about it.
Anyone know what that could be about?
Only mod I've done that could have had any impact is a K&N FIPK.
My old truck had a check engine light that would come on and off, I cleaned the Mass Airflow Sensor and it never came on again 8-) But if your lights only coming on right after you unhook your battery it might just be that your resetting your ECU so you truck is trying to relearn the air-gas ratio. I don't know though... What do you guys think? would this be totally out of the picture?
Just my two cents...
Old Mar 7, 2007 | 11:54 AM
  #149
partyman66's Avatar
I ended up not having to replace it. Just cleaned out the one that was in there already. Turns out it wasn't even bolted onto the pipe. The previous owner didn't use any nuts to hold it on, and it was just resting in the pipe. I'm thinking that maybe I went over a bump and the thing bounced up and out of the pipe a bit and tripped the CEL. I've since gone and cleaned the 02 sensor and bolted it back in, and the light hasn't come on again in a week.
Old Mar 7, 2007 | 05:45 PM
  #150
YotaFun's Avatar
How many miles have you driven?
The reason I ask is it takes a few miles for the computer to recheck itself.
Old Oct 11, 2011 | 04:44 AM
  #151
Ogredaddy's Avatar
Check the tips of the ignition coil side insulator shafts
and the tips of the insulator shafts on the other side as well.
If you see a thin black burn mark across the tip, the
insulator is arcing over causing that cylinder to miss-fire.
I'm trying to find a reliable source for "Correct" Ignition Coil caps, insulators and a full set of wires at a reasonable price.
"99 Tacoma 4X4 SR5 V-6 3.4 TRD extend cab.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
razorman8669
Jul 12, 2015 12:13 PM
