Check Engine Light... I have Had Enough...
Old Nov 17, 2006 | 01:33 PM
  #81
YotaFun's Avatar
Originally Posted by fireteacher
oooops, i was late.
glad! clean your throttle body while you were in there?
What kinda cleaner should I get for that...
I will be doing that before work tomorrow!!!
  #82
YotaFun's Avatar
pull your efi fuse also for a couple seconds. go to autozone and have them clear it. tell them you just replaced the o2 sensor if they ask
I hear about this EFI fuse, is it listed in the fuse box detials to pull?
Old Nov 17, 2006 | 01:36 PM
  #83
YotaFun's Avatar
Also since autozone is a bit of a drive from me (school is closer to the auto zone but school is also a good distance)
Do you think naa will clear the code for free?
Old Nov 17, 2006 | 01:39 PM
  #84
TX-BLKRUNNER's Avatar
dude just unplug the battery. if there is nothing wrong with it the light will not come back on. if cleaning the MAF did not solve the problem then the light will come back on.
Old Nov 17, 2006 | 01:40 PM
  #85
YotaFun's Avatar
Ok...
I think the throttle body still needs to be cleaned though...
What cleaner should I use?
Old Nov 17, 2006 | 01:41 PM
  #86
carb cleaner will work, i would go to toyota and buy a new gasket to replace the old one with though.
Old Nov 17, 2006 | 01:43 PM
  #87
YotaFun's Avatar
good idea...
I look at my odometer just now...
I am 85 miles from hitting 100k...
I can't WAIT!!!
I am so excited...
I never owned a car that had lower than 150K on it...
So this will be aswome to watch it roll and hit 100K!!!
Old Nov 17, 2006 | 02:12 PM
  #88
fireteacher's Avatar
lol. your funnnnnnny!
i buy crc everything.
get what you want
no need to go to autozone if it went away, and yes...neg cable will do the same.
make sure you take a pic of the 100k or youll be upset!
Old Nov 17, 2006 | 02:21 PM
  #89
Ironmike4x4's Avatar
Yes even my '98 didn't have the screws and I just sprayed the MAF inside as I found after searching and posting. As far as the TB (throttle body) I used an old toothbrush (or just reuse it don't I don't care) and sprayed the "mouth" of the trottle body while using a screw driver to hold it open then brushed the grime. You'll have to spray the toothbrush to clean it and maybe even use rags to help clean the the butterfly opening.
Don't get so stressed out about everything. You won't add a minute to your life. Remember that there are worse things that can happen other than not having a vehicle to drive. We had a tech at a shop I used to work at that just wouldn't slow down and spazzed over everything when he couldn't figure out a problem. Once he slowed down then things began to make sense and he could fix anything to his abilites. It was me...
Old Nov 17, 2006 | 05:32 PM
  #90
Elton's Avatar
no it wont you need
Old Nov 17, 2006 | 06:18 PM
  #91
YotaFun's Avatar
Yeah thats me too...
Man Can I Tell you Guys Though...
Cleaning that MAF was something I should have done a while back...
Boy do I feel a dif in power...
It's so nice ::grins::
Thanks again y'all....
I will stop spasing out...
I am glad i got y'all to help me...
If I didn't I would be even more broke then I am now...
Old Nov 17, 2006 | 06:35 PM
  #92
just glad you LISTENED!! kinda like yelling at you..."BRAD, (still dont know your name..sig?) SHUT up for a sec a relax. Now heres where you can start" you "BUt...BUT..." lol. its all good man!
you should count to 10 or something! maybe your maf really had something to do with that code....maybe not.....???
hahahahaha
Old Nov 17, 2006 | 06:38 PM
  #93
curious..how many times have you started the runner since you reconnected the battery?
Old Nov 17, 2006 | 06:42 PM
  #94
YotaFun's Avatar
I have started teh Runner about 6 times...
I have driven about 20-30 miles since I did everything...
why do you ask?
Old Nov 17, 2006 | 06:44 PM
  #95
YotaFun's Avatar
Fireteacher I was wondering, where did you get your shackles?
Old Nov 17, 2006 | 06:48 PM
  #96
ace hard where. i shoulda waited and got some real ones as these have the pins going through instead of threads, kinda like stock hitch pins..oh well you can get the hangers from steve at sonoransteel.com top notch, but i dont think youll want em there with your oem bumper...might look silly
just seeing how many times you started it. i think it takes 3 times to throw the light. not 3 starts but 3 times to throw the code. it could be intermittent times...i was just askin.
im confident you solved the riddle to your problem
Old Nov 17, 2006 | 06:52 PM
  #97
YotaFun's Avatar
I guess I will have to find an Ace Hardware, Lowes And Home Depot Didn't have big enough ones and neither did Sears Hardware...
I think I did too...
I feel a huge dif now that it is clean...
And I am sure I will feel a bit more once I get the throttle body clean...
And then after that...
Deck Plate Mod Here I Come!!!
Old Nov 18, 2006 | 11:35 PM
  #98
Matt Tat's Avatar
P0304 4th cylinder misfire
I brought my Tacoma in to the dealership again this morning from yesterday and they figured out that the cause of my check engine light....is because of my 4th fuel injector going bad...They quoted $500 to replace ONE injector...yeah right! I found a set that would be nice to have on my truck from the URD site...I will be ordering the Bosch 318cc, 6 for $389.99....not a bad deal for 6. =) I already am expecting a supercharger in the next week or so...so excited! any ideas on what upgrades should be recommended. All advice will be appreciated! Thank you all!
Old Nov 18, 2006 | 11:39 PM
  #99
Matt Tat's Avatar
Originally Posted by 91TPU
hows your distro cap and rotor? when i changed mine i think 2 and 5 electrodes were worn a bit more then the other. and the rotor was just beat. i was gonna say coil, but thats been changed, so hmm...clogged injector?, your timing could be way off, maybe you jumped a tooth, or two on your timing belt, all just guesses
I apologize for sounding like a newbie, but where is the distributor cap and rotor located? I am not thinking straight and would want to know where its at...haha well I actually have a new timing belt, water pump, and thermostat on its way to my house...I am at almost 82,000 miles...I thought that the belts can last up to 90,000? am I wrong? hmmm
Old Nov 18, 2006 | 11:54 PM
  #100
YotaFun's Avatar
You have the 4 banger I presume right?
Cause if I am not mistaken I don't think the 3.4L acuatlly has a distributor but coil packs...
