Caliper Help 4runner
I just installed a left caliper in my 4runner and have 2 questions.
In the box the caliper came in were 2 copper o ring/crush washers that I usually associate with banjo fittings.
What are these for? I did not see a place to use them.
Also I used 16 oz. of brake fluid when bleeding and still do not have a firm pedal.
Do these calipers hold that much fluid?
thanks
thanks
when you took off the old caliper did you plug the line so the fluid didnt empty out?
or did you let the master cylinder empty out?
if thats the case youll need to bleed the entire system including the master cyl itself.
well if you still dont have a firm pedal you either have a leak somewhere (mabye internally in the mc) or you have a vacuum leak in your brake booster or you still have air in the lines somwhere. thats all i can think of right now
Originally Posted by Marc
Mine doesn't use banjo bolts, just a flare nut.
I got BRAKES! Turns out the generic metric brake line I bought that goes from the caliper to the hose was not quite the right one. It wasn't leaking fluid, but it must have been letting air in. I ordered some OEM one's from my dealer ($8.00 ea.) and the problem was solved.
thanks for the help
thanks for the help
Flying91
45
Apr 11, 2024 04:39 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
