body lift and auto tranny shifter
Old Sep 3, 2004 | 11:35 AM
jacksonpt's Avatar
Senior Member
After I did my 2" BL, I noticed that the little red line next to my auto tranny shifter didn't line up with the gear I was in. Anyone else notice this? Is there a fix? My wife is really nervous driving it this way.
Old Sep 3, 2004 | 12:08 PM
waskillywabbit's Avatar
Talking Dunno
Mine did that crap all the time, just watch what it says on the dash and you'll be fine. Now that the body lift is off, it is gone. I'm sure the body lift messes up the angle/linkage and throws the little orange indicator off a tad.
Old Sep 3, 2004 | 12:22 PM
TStango's Avatar
Mine did this as well. I fixed it by loosening the bolt on the shift linkage, allowing for further adjustment, then I tightened it up when it was right. Maybe it will help to put the transmission in Neutral (engine off of course & parking-brake on) and climb under, make the adjustment, and peek up at the indicator to see if it is lined up.
Old Sep 3, 2004 | 12:35 PM
mt_goat's Avatar
Mine did it on the tranfer case shifter after a 1 inch BL, but not the transmission shifter. I had to lower the transfer shifting linkage about 1/2 inch to get it shift right. The little red line still doesn't line up right, but it works fine.
Old Sep 3, 2004 | 01:21 PM
SEAN_at_TLT's Avatar
Mine lines up near perfect after adjusting the linkage as Tsango described...
Old Sep 3, 2004 | 11:29 PM
calrockx's Avatar
i'm 1.5" body lifted and mine is good. i have noticed it be off a couple times, but then it somehow got back to normal. good to know i can fix it if needed.
Old Sep 4, 2004 | 01:01 PM
jacksonpt's Avatar
Senior Member
NEWBIE!!!
96s don't have the display on the dash. *sheesh*
Old Sep 4, 2004 | 01:02 PM
jacksonpt's Avatar
Senior Member
Which nut are you talking about... under the center console, or down by the tranny?
Old Sep 4, 2004 | 01:03 PM
Talking Lol
NEWBIE!!!
Uh....and that is my problem how?
Old Sep 5, 2004 | 01:45 AM
Mossback74's Avatar
Look at RB's install instructions
Old Sep 5, 2004 | 03:37 PM
Rays94runner's Avatar
wow, I dont have a lift, but mine doesnt line up either which is not really a prob just anoying. Im going to see if I can adjust mine
Old Sep 6, 2004 | 07:25 AM
Mossback74's Avatar
although I'm not positive, I think it's different for the 2nd gens
Old Sep 6, 2004 | 12:58 PM
4runner4me's Avatar
I just losened the trans shifter linkage when I put on the lift and then tightened it up after I put on the lift. I figured if it was loose it would adjust its self. It didnt end up moving but just a little bit. My shifter has never had any problems with the red line.
Old Sep 7, 2004 | 04:04 AM
jacksonpt's Avatar
Senior Member
Originally Posted by Mossback74
Ah, sweet - thanks for the pic man!
Old Sep 13, 2004 | 04:04 AM
jacksonpt's Avatar
Senior Member
I finally got around to adjusting the linkage - worked great. A little PB Blaster and the nut loosened right up. I tried a few different positions until I found one that worked. For me, I had to slide the botl all the way forward in the linkage.
Thanks guys.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Iceman4193
Jul 15, 2015 04:48 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
