Rear Drum
Old Sep 12, 2004 | 10:27 AM
vtruong1's Avatar
Rear Drum
How do you get the drum off? My e brake is off, but the thing is still stuck.
Old Sep 12, 2004 | 11:47 AM
Yoter's Avatar
Guest
On mine a couple good taps from the hammer usually losen it up.
Old Sep 12, 2004 | 12:13 PM
No to highjack but will that give access to the lugnuts? I need to replace one of them.
Old Sep 12, 2004 | 12:16 PM
superjoe83's Avatar
yes, once the drum is off, you can pound the old one out of the back and install the new one
Old Sep 12, 2004 | 12:19 PM
BeaterToyota's Avatar
There is a little rubber plug in the backing plate that you need to pry out. Then reach through the hole with a couple of screwdrivers or similar tools and turn the adjusting wheel to pull the brake shoes in a little.
Also, there should be some threaded holes (mine are 8 mm) on the outside of the drum. You can thread the right sized bolts into those holes (usualy 3 or 4 holes) and as you thread them in it will push the drum off.
Also, as already mentioned, a big friggin hammer can help speed up many automotive repairs.
Old Sep 12, 2004 | 12:20 PM
Yoter's Avatar
Guest
lol I was picturing the wheel still on being you said lug nuts not lug nut studs. Scared me for a minute. Good luck
Old Sep 12, 2004 | 12:31 PM
Thanks for the info (man this site is amazing!). Yes it is the lug nut stud (or whatever site on the rear drum) it broke off yesterday (argh).
Old Sep 12, 2004 | 12:46 PM
vtruong1's Avatar
I beat it with a hammer, I turned the adjusting wheel in the back, I beat it some more. No dice, I gave up...
Old Sep 12, 2004 | 04:29 PM
Jason B's Avatar
Put some anti-seize on the backside after you get it off. This will make it much easier to get off next time.
Old Sep 12, 2004 | 04:36 PM
95_4X4Runner's Avatar
In the picture above, you'll notice there are 6 holes in between each wheel stud. On the one nearest the hammer, there's an extra hole, and one across from that. Like someone else said, use two bolts in these holes, to push the drum off, you'll need a bolt with the right size thread, with about 2 inches of threads to have enough bite to push the drum off.
Old Sep 13, 2004 | 04:53 AM
vtruong1's Avatar
Thanks guys, I thought it was going to be an easy process. But after not being able to get the damn thing off, I dropped it off at a friends. Sitting in the hot sun tryin to get if off just wore me out.
okamikai
Apr 30, 2018 10:19 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
CanRunner
Jul 20, 2015 01:29 PM
icentropy
Jul 14, 2015 10:23 AM
