Blown CV Boot, now what
Old Mar 24, 2005 | 10:34 AM
oly884's Avatar
Guest
Originally Posted by colsoncj
If the tear just happened, I'd get a boot fix kit, i don't think they're more than 20 or 30 bucks, and you don't have to pull the CV to install it, just cut the old one off, wrap the replacement around and connect all the clips. Them seem to work pretty well, although they aren't as good as a solid boot. If the tears been there for a while, personally, I'd drive it til it makes noise, then change it (if i didn't feel like doin it right away), or just change it now.... my $0.02
I'd change it now, the problem is, if you drive it till it makes noise, then you'll be looking at replacing the joints as well.
Old Mar 24, 2005 | 10:46 AM
koyota93's Avatar
I can get one for $80 out the door plus $50 core, if you really need one.
Old Mar 24, 2005 | 10:49 AM
getitdone's Avatar
Originally Posted by fillsrunner4
i had that problem once and i brought it to a shop. Big mistake. They found more problems and it ended up costing me a lot.
This is the dumbest thing I have ever herd. How is it the shops fault that YOU had more problems? They found them for you and fixed them before they left you stranded or costing you more. You could have refused to have them repaired. It's not like you had to pay more because you went to a shop. I can't believe you said that!
Definatly replace the axle and not just the boot. Then go get manuel hubs.
Old Mar 24, 2005 | 11:18 AM
Tofer's Avatar
Sponsor
thanks but i can pick one up at autozone for $70 plus $45 core... thanks anyways..
Old Mar 24, 2005 | 05:00 PM
  #25
midiwall's Avatar
Originally Posted by oly884
Originally Posted by ToferUOP
thats a good idea... what kind of grease do i need to buy to do that?
It'd say some gear grease, they'll have it down at NAPA, or any other auto parts store.
no no no no!
You have to use the right stuff - the joints are not made out of your standard cast-iron-any-old-grease-will-do type metal. That, plus the heat that they have to put up with will make some greases break down.
Get the CV Boot kit from a dealer, you're gonna need it anyway. In fact, get two so you have an extra set. They're only $40ish a piece.
The kit comes with TWO kinds of grease. The BROWN grease goes on the OUTER joint, the GREY grease goes on the INNER joint.
There's a step-by-step in this thread along with other info:
https://www.yotatech.com/forums/f116/cv-boots-done-48273/
To note, one person mentions that he found new axles ready-to-run (boots and lubed!) at Car Quest for $66.
Old Mar 27, 2005 | 09:14 PM
  #26
Tofer's Avatar
Sponsor
relpaced it today... messy job but not too hard, it took us longer trying to get the thing lined up so that it would slide out then it did anything else...
Old Mar 28, 2005 | 12:37 AM
  #27
midiwall's Avatar
Well done!
The 2nd time is a lot easier.
Old Sep 21, 2010 | 12:24 PM
  #28
Tofer's Avatar
Sponsor
I know this thread is 5 1/2 years old and my truck doesn't have cv axles anymore, or the same motor, gears, tires, or rear suspension, but based on recent threads, bumping hella old threads just to comment on them seems to be the cool thing to do!!!
Old Sep 21, 2010 | 12:35 PM
  #29
Mauzer's Avatar
I think it worked, your so cool now that your tied with Wabit on the calendar poll...nice work
Old Sep 25, 2010 | 06:25 PM
  #30
SoCal's Avatar
I appreciate the bumped thread I am going to get gears this wednesday 4.88 front and rear and just noticed a blown inner boot on the passenger side.
I have manual hubs but my question is will this be a easy repair since a shop is doing the gears don't they have to take the front axles out anyway?
Should I get all the boots replaced?
Old Sep 26, 2010 | 09:44 AM
  #31
Tofer's Avatar
Sponsor
There are a couple things that will make changing out cv's for one pound out the studs on the diff and replace with grade 8 bolts. Are you paying the shop to install new gears or to swap out the whole diff?
Old Sep 26, 2010 | 12:16 PM
  #32
SoCal's Avatar
In the front they are just going to do gears, Do they have to pull the half shafts anyway?
Old Sep 27, 2010 | 02:18 PM
  #33
SoCal's Avatar
Well the answer is yes, they have to pull the half shafts anyway to do the gears so I bought some from Kragen so I can have the warranty and the shop doing the gears is going to put them in for free. It was Perfect timing to have a boot blow out Kiling Two birds with one stone.
4banginRunner
Nov 13, 2015 05:23 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
89YodaRunner
Sep 30, 2015 02:18 PM
