Block Heaters
Old Dec 10, 2002 | 05:42 AM
jrallan26's Avatar
Block Heaters
I have been thinking about installing a block heater on my truck. Are they an easy installation? Do you recomend to use them?
I live in Iowa and sometimes it gets downright frigid out here!
92 Toyota 4x4
03 Tacoma 4x4x4 dr.
99 Toyota Camry
Old Dec 10, 2002 | 05:46 AM
Bob K's Avatar
I was curious about that as well, where do they install?
Old Dec 10, 2002 | 09:11 AM
Highland Runner's Avatar
I had a write up that somone had done but can't find it on my computer. Basically what you do is knock out one freeze plug and replace it with the block heater. The writeup said it was a very simple job. I think the part can be gotten from partznet.com for less than $30.
Old Dec 10, 2002 | 09:28 AM
Bob K's Avatar
Thanks that's what it looked like you did with it but I was not sure.
Old Dec 10, 2002 | 09:32 AM
tkrispin's Avatar
Check out post #6 right here.
Block heater under $30. But does it circulate the coolant, or just keep one part of the block warm? I guess I could check out howstuffworks.com..........
Old Dec 10, 2002 | 09:38 AM
02SilverV6
Guest
Posts: n/a
I have seen some that replace your oil dipstick with a heated one. It warms the oil up and the heat radiated through the metal and keep the motor somewhat warm. I think the real purpose of it is to keep the oil warm and thin so when you start it it will be able to flow easier and get things lubed up faster.
Old Dec 10, 2002 | 05:18 PM
jrallan26's Avatar
Install by removing a freeze plug? Are the "freeze plugs" difficult to remove?
Jonathan
92 Toyota 4x4
03 Tacoma 4x4x4 dr.
98 Camry
Old Dec 10, 2002 | 06:29 PM
Arnold's Avatar
Jonathan
92 Toyota 4x4
03 Tacoma 4x4x4 dr.
98 Camry
Mine was a PITA to remove.:mad: I practically had to drill the entire thing out. It was worth it though 'cuz it sure is nice having an instantly warm heater on cold mornings. Another benefit is that it reduces needless wear and tear on my engine.
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
woodyth
Sep 30, 2015 06:32 PM
gyroscope7
7
Sep 27, 2015 08:39 PM
LotOMiles
Sep 14, 2015 11:45 PM
