auto tranny fluid question
Old Mar 27, 2007 | 07:16 AM
mkgarrison5's Avatar
hey guys just curious on what you guys use for auto tranny fluid i have an 02 tacoma 4x4 extra cab v6 auto and i just drain and fill every 15k miles or so with valvoline high mileage (83k miles on the truck)... never really had it brown just a dark red... what do you guys do... i have never flushed this truck nor do i think its ever been flushed
Old Mar 27, 2007 | 09:23 AM
GSGALLANT's Avatar
I drain it, remove the pan to clean the filter, refill the pan with Toyota ATF, then flush out the rest of the fluid through the cooler lines.
Old Mar 27, 2007 | 09:26 AM
rearviewmirror's Avatar
I need to change mine.. is there a write-up on the trans line refill method?
Old Mar 27, 2007 | 09:50 AM
never removed a cooler line before all i do is just open the plug on the train pan. let it drain for a good hour or so. it usually drops about 5qts or so. its best to let it drain over night. but since i do this every 15k miles or so my tranny fluid from what i can tell is fairly clean.....
anything wrong with valvoline high mileage auto tranny fluid??
Old Mar 27, 2007 | 09:53 AM
oh and when you take the pan off do you have to replace a seal?? and how do you clean off the screen?? never done it. i just drain and refill
Old Mar 27, 2007 | 02:01 PM
Elkaholic's Avatar
Gadget explains what there is and what he uses here.
http://www.gadgetonline.com/TransFlush.htm
Old Mar 27, 2007 | 02:22 PM
ebelen1's Avatar
I had a shop use the machine to get all the old fluid out and replaced w/ Amsoil synthetic. At the same time, we dropped the pan and cleaned the magnets. Now, I just drain and refill annually. The drain and refill is only a small percentage of the total fluid but since I've done this, the drained fluid is still red as can be.
Old Mar 27, 2007 | 02:42 PM
ARB1977's Avatar
The first time i did i disconnected the return line going into the tranny, drained the pan the refilled with 4 qrts redline D4, started her up and pumped out a gallon of fluid, shut her off and fill the pan with another 4 qrts. I did this about 4 times. Now every 30K i just drain whats in the pan. Right now ive got a mix of Redline D4 and Amsoil Universal ATF and to make filter changes eaiser i added a permacool remote filter kit between my stock and TRD cooler.
Old Mar 28, 2007 | 03:47 AM
anyone use valvoline high mileage auto tranny fluid??
Old Mar 28, 2007 | 02:42 PM
GSGALLANT's Avatar
Toyota ATF is not that expensive, and it works great, I would stick with that or a high end synthetic if you want to spend more money. We have quite a few un-official writeups on doing a full flush yourself. See this thread to get you started.
Old Mar 28, 2007 | 07:41 PM
metalhed's Avatar
I use the regular Valvoline, no problems.
I just drain the pan and refill, once a year
Old Mar 29, 2007 | 03:48 AM
can you explain your method in better detail.. interesting
Old Mar 29, 2007 | 08:07 AM
GSGALLANT's Avatar
It's the same method as in the link I posted in post #10... essentially. Although I don't recommend pumping it out a gallon at a time, though, because the pan only holds a little over a gallon, and you want to make sure you always have fluid at your pump's suction (which is the opening at the bottom of the filter). After I've drained, removed, cleaned, re-installed and re-filled the pan, I flush it approx 1 quart at a time to get the remaining fluid replaced. I also remove and clean the filter screen while the pan is off.
Old Mar 29, 2007 | 09:31 AM
gotcha thanks man!!......... if i were to ever "flush" thats how i would do it.. personally i just drain and refill.. it all gets mixed together with old and new fluid. though i would think getting atleast a few quarts out of the coolant line maybe a good thing to do. maybe ill do it your way but not for the whole 14qts or so. i think half would be suffice...
Old Mar 29, 2007 | 06:28 PM
GSGALLANT's Avatar
If you are considering going through the trouble of doing half... why not finish the job while everything is set up? It's only another 5 quarts, then you know that all your fluid is clean.
Old Mar 30, 2007 | 03:41 AM
yeah true just dont like that fact that i would have to crank the truck a dozen or more times
Iceman4193
Jul 15, 2015 04:48 PM
KBar
Jul 13, 2015 06:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
