ARB compressor - where to install?
Old Mar 26, 2007 | 12:56 PM
safado4's Avatar
just curious (and need inspiration), where did you install your ARB compressor? pics would be nice too if you could. I've got a mini compressor from ARB and havin a tough time deciding where to put it... what would give the best performance? would outside of the engine bay (i.e. towards the back of the vehicle) be out of the question? - might be because of noise / heat? goin to moab for easter weekend so any info before then would be great...
thanks!
Old Mar 26, 2007 | 01:07 PM
Yota Tony's Avatar
I've seen most people install them under the hood or in the rear cargo area.
The draw back with the cargo area is you'd hear it flicking on and off.
No pics though, sorry.
Old Mar 26, 2007 | 01:17 PM
RunnerUp's Avatar
my buddy has his installed in the rear hatch of his jeep cherokee, you can only hear it cycling on and off when you have power going to it. when i get my ARB im going to mount mine inside my rear hatch
Old Mar 26, 2007 | 01:22 PM
safado4's Avatar
hmmm.. i'm not too worried about the noise if it's just when it's giving power. it might even be cool, like when you hear turbo or a supercharger whine. does it give off heat that could damage the plastic or anything?
Old Mar 26, 2007 | 01:29 PM
mt_goat's Avatar
One other thing to consider is if a seal goes out in the locker gear oil can get pushed up the air line and the soleinoid will puke it out the relief valve. So that can be a bit messy for an interior mounting.
Old Mar 26, 2007 | 10:37 PM
safado4's Avatar
so if I go under the hood and install there, what would the best mounting place be? (basically a stock 3.4)
Old Apr 26, 2007 | 07:39 PM
toy_tek's Avatar
So NOBODY has a picture of an under hood ARB compressor install on a 3rd Gen?
Old Apr 26, 2007 | 07:47 PM
d0ubledown's Avatar
i've got my compact compressor mounted on the passenger side...i think just between the abs module and the airbox. mounted on the wheel well hump. inside the cab...the novelty of compressor noises and blow off will wear off quickly. depends on how many lockers you're plumbing to it. mines only for the front, so it made more sense to mount it as close to the front locker as possible...
i can have some pix of where i mounted it tomorrow...
Old Apr 26, 2007 | 08:41 PM
Albuquerque Jim's Avatar
Passenger fender well. I just made a small mounting plate and actually used 3 existing bolt holes.
Old Apr 26, 2007 | 08:44 PM
xcmountain80's Avatar
I have a Viair mounted pas. side and was able to utilize factory threaded holes for the mounting feet, then wired it to a factory defrost switch.
Aaron
Old Sep 16, 2007 | 09:33 AM
Tofer's Avatar
Sponsor
bump... i'm trying to figure out where to install my compressor in my 2nd gen. i went with the fullsize compressor with plans on adding a 10 gal tank for OBA.
Old Dec 22, 2007 | 03:33 PM
toy_tek's Avatar
Update: my full size compressor install can be found here: https://www.yotatech.com/forums/f31/...lready-125245/
Old Dec 22, 2007 | 03:52 PM
i ended up mounting it to the drivers side fan shroud. It was an east place to put it w/out having to move anything around or building a mounting plate. So far its held up welland ive had it there for a few years.
RatOmeter
Oct 22, 2015 03:17 PM
nick9455649
Sep 11, 2015 05:10 PM
A2theK
Jul 12, 2015 10:46 AM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
