Another tire preasure question for normal driving
Old Feb 3, 2003 | 11:02 AM
L33T35T 4Runner's Avatar
I have a 95 4runner SR5 with 31x10.5R15s on there... stock rims.
on the door it says on 225/75R15 (STOCK) use 26psi in the front and 35 in the back. so now that i have 31's... what should i run?
thanks
Old Feb 3, 2003 | 11:06 AM
jacksonpt's Avatar
Senior Member
run a psi that allows them to wear evenly. Seems like that's typically between 30 and 35 psi, but it depends on the tire.
Old Feb 3, 2003 | 11:52 AM
... anybody else?
Old Feb 3, 2003 | 12:04 PM
Paul H.'s Avatar
I run 32psi up front, 35psi in the rear.
Old Feb 3, 2003 | 12:39 PM
Corey's Avatar
Co-Founder/Administrator
I have ran 32 to 35 PSI in 31" tires since '90, and I get even tread wear.
I currently am running 35 PSI an all of my tires.
Old Feb 3, 2003 | 01:18 PM
richeyma's Avatar
I'm running 35psi as well in all four tires and I have even tread wear (31x10.5" BFG AT's).
Old Feb 3, 2003 | 01:24 PM
Hokiez97's Avatar
Tire Pressure
It depends on the tire and what rating it is...
I have Michellin LTX AT's 235 x 75 x 15...
Their max load is 50 psi.... I try to keep radials close to their posted limit.... I typically run 45 and 45....
Do a search on tire pressure... I answered some body's post a while back and had a lengthy discussion about this...
Mike
Old Feb 3, 2003 | 01:28 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Re: Tire Pressure
Mike
:eek: If I ran near the max pressure of my tires, I'd be able to tell if the penny I ran over was heads or tails...
Old Feb 3, 2003 | 03:05 PM
Eighty7ToyTruck's Avatar
i run 28-32 psi in all 4, tires wear well even though the alignment is shot.. 235/75/r15 bfg ats
Old Feb 3, 2003 | 03:43 PM
rowan's Avatar
mine are 31 psi all around i think. tread seems to be even. think i might bring it up a little though if i get a chance.
Old Feb 3, 2003 | 03:56 PM
Cebby's Avatar
Same for me, except I'm running 32x11.5 BFG AT KO's...
Old Feb 3, 2003 | 04:21 PM
Victor's Avatar
I run 38 PSI front and 40 PSI rear. After lots of playing with the pressures those were the best settings as far as a compromise for fuel mileage and ride comfort for my truck.
Old Feb 3, 2003 | 04:29 PM
what kind of driving do you do? how are you in the turns?
Im freakin nuts in turns...
also, what year 4runner?
Old Feb 3, 2003 | 04:54 PM
Victor's Avatar
I have a 94. Mostly city driving and my offroad driving is in the sand. Less pressure gives a nicer ride but acceleration was sluggish and mileage sucked. Of course my last car was a Mustang 5.0 with lots of mods so what others call firm may seem sloppy to me. Any more pressure in the tires and I really feel the bumps and the back hops on big dips. A better compromise was 36 front 38 rear but I filled my tires a while back and now the weather is much warmer so I adapted to the slightly higher pressures over time and like them even more.
Old Feb 3, 2003 | 06:42 PM
you have 31's right?
I'll try out your tire preasures tomorrow
thanks
Old Feb 3, 2003 | 06:49 PM
Victor's Avatar
31's. Sorry I didn't mention that before.
Old Feb 4, 2003 | 05:20 AM
Hokiez97's Avatar
Tire pressure cont.
Hey guys,
Remember a "floatation" tire by design normally utilizes less pressure then a regular road tire....
Hey RICK F, Yep I feel all the bumps in the road. For me and my "expensive" tires, I would rather replace the shocks (OEM Replacements)....
Save a little more money...........:confused:
Mike
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
wilbertd
Jul 6, 2015 07:39 AM
