Airbox Question!
Old Sep 16, 2002 | 04:17 PM
Yochdog's Avatar
Airbox Question!
OK, after reading many articles advocating every possible set-up, I would like to know the forums opinion on whether it is just as advantagious to do the deck plate mod VS. a upgraded intake system.
Also, since I do not do much offroading, would I even have to have the cover plate for the hole in the airbox?
Finally, with so many people saying an upgraded intake drowns a supercharged engine with air, how much does an upgraded fuel pump cost? And does that solve the fuel delivery problem with the supercharger and a high flow system?
THANKS!!
Old Sep 16, 2002 | 04:30 PM
pfdaxe's Avatar
Well.....the stock air box with mod works well. I took my polished Ingen intake off because of fuel starvation with my supercharger. It runs way better with the stock air box and I don't feel like droping alot more money to upgrade my fuel system (about $1200 to do it right) to provide more "premium" fuel into the system. The mod to the air box that worked for me was to just remove the elbow. I did have the front cut out like others have suggested, but living in Arizona, it was letting to much dust and dirt in.
Just my 2 cents...
Paul
Old Sep 16, 2002 | 10:40 PM
Bob_98SR5's Avatar
Yoch:
I finally did the airbox "deckplate" mod this weekend (gotta update the sig). It was alot easier than I expected.
One advantage is that its very inexpensive to do. Second, it gives you the opportunity to seal it off, whereas if you did the elbow mod or your intake system (injen), you would just be sucking in water. Now I don't know where you're from, but even if its a remote possibility, its something to consider.
As for the deckplate mod, I really think its the best of both worlds. Sure, it doesn't look as aesthetically pleasing as a K&N/Injen type system, but it does its job well.
Some tips that I think might be useful from my weekend install:
- Offset your cut to the upper left hand corner. If you have it perfectly centered, its a bit more difficult to put the deckplate on b/c of the windshield wiper fluid tube.
- When drawing around the deckplate for your hole cut, use a white pen or some other light colored marker
- Remove the MAF! Then you really don't have to worry about getting plastic shavings in it.
- Get a hole saw thing for your drill. I believe you would need a 4" hole saw. Might be 4.5". I bought a Rotozip bit and it was not as easy or as clean as I expected. Actually, it was a pain b/c everytime it hit the plastic waffle on the back, it would skip and jump. I guess I just don't have steady hands!
- Instead of worrying if I bought the right silly-cone safe sealant, I used a piece of rubber and cut it to shape. I found a square at my local hardware store for a buck, traced the shape, and cut it. Much cheaper than a $5 tube of sealant.
- Wash it out w/ a high pressure hose to get out all the plastic shavings. I went a step further and washed it w/ a soapy brush .
Hope that helps.
Bob
Old Sep 17, 2002 | 03:46 AM
jacksonpt's Avatar
Senior Member
Advantages to the deckplate...
- easy to do, takes about an hour
- very inexpensive, about $20 for deckplate and silicone
- same performance gains as a typical intake system for less time and money
Disadvantages to the deckplate...
- doesn't change your exhaust note
Advantages of intake system...
- good ones will give you a throatier sound
Disadvantages of an intake system...
- expensive, typically between $150-$200
- most air filters are made by or modeled after the K&N filter, which has been shown to have poor filtering capabilities
Old Sep 17, 2002 | 05:50 AM
Stump1883's Avatar
Okay I really want to do this airbox/deckplate mod, can anyone psot the link up here for me. I have a free weekend coming up and would really like to do this mod. Thanks to whoever.
Old Sep 17, 2002 | 06:24 AM
Corey's Avatar
Co-Founder/Administrator
Stump, look in our Tech section on the index page here.
There are two deck plate mod write-ups in there to guide you through it.
Old Sep 18, 2002 | 03:33 PM
C2damuthafuqinLO's Avatar
If you get an intake...it makes the supercharger less effective? Can anyone enlighten me on this? I did the deckplate mod..and planned on getting an exaust system w/ intake to boost the HP even more...but down the road...hopefully next year...i'd like to get a supercharger? So what type of ill effects will there be? What would i have to do for maximum performance..?
Old Sep 18, 2002 | 05:13 PM
pfdaxe's Avatar
You won't need the intake with the s/c. Aftermarket intakes dump too much air into your system. (Unless you want to completely upgrade your fuel delivery system).They work great without s/c. Do the deck mod, s/c and exhaust and you'll be set. Believe me....I removed my Ingen intake and put my stock air box back on when I installed my s/c.
Paul
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
