aftermarket orsion bars replacment 95 4runner
Old Aug 23, 2005 | 09:14 PM
airrikk17's Avatar
im about to replace the stock torsion bars with a used set of aftemarket rancho ones , anyone have any hints tips or tricks to doing this job ?
do i need to have the truck up with no pressure on suspension or on the ground ?
i bought the new bolts so that wont be a problem ?
any special order i need ot start removing nuts and bolts ?
any write ups for this job ?
airrikk17
Old Aug 23, 2005 | 11:09 PM
mastacox's Avatar
You have to jack up the truck, and you will probably need new bolts, so it's good you have them... The bars have specific notches, so they only fit in one orientation (do NOT hammer them, they will fit easily.) Grease the ends of the bar before installing it too, to prevent squeaking and what not. It would probably be easiest with a friend to help guide the new bar in, but can be done alone I suppose. When adjusting them, you should jack up the truck, tighten, and then let it down. Don't tighten while on the ground, could lead to pain! (if the bolt breaks, it will send that torque arm through your floor, and drop the truck on you!)
airrikk17
Old Aug 24, 2005 | 05:33 AM
geneius's Avatar
umm...what he said.
Oh, the passenger's side is a PITA, so take your time. I had to unscrew a bracket (forgot which one) to maneuver the T-Bar in place. And...make sure you get the notch in the rear set up correctly before sliding the front end into the upper a-arm socket or that will be PITA #2.
Good Luck.
Old Aug 24, 2005 | 06:15 AM
One More Time's Avatar
PB Blaster the bolts for a few days before you pull the old t-bars
Old Aug 24, 2005 | 12:55 PM
Steveh29's Avatar
I second having a new set of torsion bar bolts ready to replace the ones you'll snap off for sure. I made that mistake and was unable to drive the truck for several days while a new part was on order. Other thing is the splined end of the bar that sticks in the A-Arm is keyed. It's hard to get the keyway lined up properly unless you draw a mark on the bar further back as a reference point. Then it's easier to rotate the bar into the proper keyed position. Here are some links on replacment and adjustment.
http://www.off-road.com/toyota/tech/torsion/index.htm
http://www.4x4wire.com/toyota/tech/torsion_bars/
Old Aug 25, 2005 | 05:52 AM
sandcrawler's Avatar
i'll be doing this mod soon, too. already got my new bolts and nuts and a generous supply of PB blaster...
also have some new hubs coming, and i've already got new gaskets for those.
gotta pick up some grease and antiseize compound next time i'm out...anything else?
Old Aug 25, 2005 | 06:36 AM
toyguy1986's Avatar
A service manual, if you don't already have one. Follow the steps in the book and you should be ok.
Old Aug 26, 2005 | 05:20 AM
airrikk17's Avatar
thanks for the links a huge help, hopfully ill get some time too do this project and a couple of others .
airrikk17
truckmike26
Jul 24, 2024 10:24 AM
voiddweller
19
May 2, 2016 09:10 PM
Gamble_STi
Jun 27, 2015 07:54 PM
leafsprings_sux
Jun 26, 2015 12:55 PM
Niameyrider
Jun 25, 2015 05:50 AM
