Adding weight to improve traction
Old Feb 17, 2003 | 05:42 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Question Adding weight to improve traction
As capable as my 2000 SR5 is in the snow, I feel as if I'm not getting a good bite and that i'm "floating" on top instead. I have 265/70/16 REVO's and I'm running them at 33 psi all around. In the past, I used about 200 lbs of sand bags in the back which improved my bite somewhat, but I hate hauling the extra weight if I don't have to. Any suggestions?
Old Feb 17, 2003 | 06:16 AM
Victor's Avatar
Your tread is probably loading up with snow and losing its effectiveness. Short of buying a more aggresive set of tires I think the extra weight is your best bet.
Old Feb 17, 2003 | 06:17 AM
Bumpin' Yota's Avatar
a more narrow tire perhaps? Also, how much higher can you inflate the current tires keeping within their limits and wearing properly?
If I was in your situation, I'd fully air up my 6ply's to 50psi so as to break through any snow, but I dont live in a place that has that white, fluffy sand falling from the sky....lol
steve
Old Feb 17, 2003 | 06:34 AM
UKMyers's Avatar
Don't add more air if your trying to get more traction!! If anything if your driving in the snow a lot I would consider airing down to around 28PSI and try that. You won't have any adverse affect at that pressure but I would air them back up if you are only driving on dry pavement or are going on a road trip or something.
Old Feb 17, 2003 | 07:36 AM
Victor's Avatar
I agree with lowering the pressure for traction. Raising the pressure will make you more susceptible to hydroplaning and the back end breaking loose on ice patches.
Old Feb 17, 2003 | 09:59 AM
HBoss's Avatar
I don't like carrying extra weight either. I aired down from 32 psi all around to 27 psi in the winter. Seems to be noticeably better.
Old Feb 17, 2003 | 11:42 AM
Rick F.'s Avatar
Thanks, gents. I'll be airing down this afternoon.
Old Feb 17, 2003 | 07:27 PM
oooooh you meant like 1" thick snow or so and then icy roads and whatnot.....
I thought you were driving on top of deep snowdrifts and not breaking through them to solid ground....hence the narrower tire and increased tire pressure comment.
Old Feb 17, 2003 | 08:31 PM
Adam F's Avatar
going to 28 psi wont make that much of a difference. Try going down to 12-15 if you arent going very fast.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kbpickens
Oct 2, 2015 03:37 PM
bradahman
Oct 1, 2015 09:24 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
EVars
Sep 29, 2015 02:06 PM
