ADD question.
With an ADD system where the hubs are always locked, if you break an axle will it damage the differential to drive on it in 2wd with only one axle turning?
I'm not sure if this has been asked before, I searched a bit and didn't find anything. Thanks,
Bryan
Bryan
Bryan
Bryan
I recently put locking hubs on mine to stop even the axles from turning. Why wear out the CV's when they're not driving anything? I spend most of my time on the road anyway so it's a plus for me to cut down on the extra drag and the extra wear.
Toyo Master
Originally Posted by Toyo_Master
I don't see why it would since the differential is disconnected when in 2WD and only the axles are actually turning. I your case one axle.
Toyo Master
Toyo Master
Anyway, thanks for the reply.
Bryan
With ADD the right axle is permantly connected and always turning the diff anyway, only the left one disconects. So if the right one breaks your diff won't turn, and if left one breaks in 2 wheel drive the diff will still turn from the right one.
I also plan on getting a Manual hub from ORS, but its like 1100$
Next mod I do... I drive far to and from work... and my CV boots are nicely grooved =)
Im not quite sure why, but I HEARD that if you brake a CV on the trail... if you cant disconnect... you either get towed, or replace it ON the trail...
but thats just what I heard... I dont know the reason or anything...
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
