ADD question.
Old Mar 17, 2004 | 09:55 AM
az4x4runner's Avatar
Question ADD question.
With an ADD system where the hubs are always locked, if you break an axle will it damage the differential to drive on it in 2wd with only one axle turning?
I'm not sure if this has been asked before, I searched a bit and didn't find anything. Thanks,
Bryan
Old Mar 17, 2004 | 10:30 AM
Toyo_Master's Avatar
Lightbulb
Bryan
I don't see why it would since the differential is disconnected when in 2WD and only the axles are actually turning. I your case one axle.
I recently put locking hubs on mine to stop even the axles from turning. Why wear out the CV's when they're not driving anything? I spend most of my time on the road anyway so it's a plus for me to cut down on the extra drag and the extra wear.
Toyo Master
Old Mar 17, 2004 | 10:41 AM
Toyo Master
I didn't really think it would hurt anything, but I wasn't sure since just one axle would be turning the diff. I haven't actually broken an axle, I was mainly curious, but it shouldn't matter soon anyway because I'm looking for a set of manual locking hubs for mine as well.
Anyway, thanks for the reply.
Bryan
Old Mar 17, 2004 | 10:50 AM
eric-the-red's Avatar
With ADD the right axle is permantly connected and always turning the diff anyway, only the left one disconects. So if the right one breaks your diff won't turn, and if left one breaks in 2 wheel drive the diff will still turn from the right one.
Old Mar 17, 2004 | 12:25 PM
Ducky's Avatar
I also plan on getting a Manual hub from ORS, but its like 1100$
Next mod I do... I drive far to and from work... and my CV boots are nicely grooved =)
Im not quite sure why, but I HEARD that if you brake a CV on the trail... if you cant disconnect... you either get towed, or replace it ON the trail...
but thats just what I heard... I dont know the reason or anything...
Old Mar 17, 2004 | 01:10 PM
Hmm, well I'm sure it can't be good to drive on one that's broken, maybe thats why they said that. It'd be interesting to hear the reasoning behind it though.
Old Mar 17, 2004 | 06:30 PM
User 051420's Avatar
With ADD, I seem to get sidetracked and forget what I'm doing. For some reason it happens to me all the time. I've heard Rittalin works well.
Ooohh... look at the kitty!
Wait, what was I saying?
Chicken12
Oct 14, 2015 03:54 PM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
