96 4 Runner Rear Wiper
Old 02-07-2008, 09:12 AM
mjf10's Avatar
Question 96 4 Runner Rear Wiper
My rear wiper is not doing a good job on the top portion of the window. I have replaced the blade and still having problems. The wiper blade appears to be losing contact with the window in that area and I do understand why, nor do I see any way to adjust it. Any suggestions? Thanks!
Old 02-07-2008, 09:44 AM
cackalak han's Avatar
This is a common problem with 4Runners. I believe the spring loses its.....spring.......which causes the contact problem. It's too cold right now, but once it warms up a bit, I am going to try to figure this out.
Old 02-07-2008, 12:24 PM
pattycakes77's Avatar
same problem here. i've tried lubing the spring and where the arm flexes from the base and at first it's ok, but then seizes again shortly after. now i just took the whole arm off, i don't miss it since it never worked anyway.
Old 02-07-2008, 12:29 PM
Yodaforce's Avatar
Tie someone to the roof rack and tell them when the wiper comes up, push on it with their hand up against the glass. lol
Old 02-07-2008, 12:35 PM
YotaFun's Avatar
Bend it.
I had to do the same thing to mine.
Work the spring then bend it right where the arm and the blade attach ever so slightly.
Works perfect now, and I have had the same blade on there since 97 :-)
4x4-runner
02-26-2017 06:42 AM
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
Niameyrider
06-25-2015 05:50 AM
Beavah
9
11-12-2013 07:31 PM
Quick Reply: 96 4 Runner Rear Wiper
