96 4 runner lift/tires/shocks setup questions
Old Jul 20, 2006 | 06:47 PM
jeremystephens's Avatar
OK HERE GOES
I WILL BE USING THE TOYTEC 3" LIFT WITH THE OME SPRINGS
WILL THIS SUSPENSION LIFT AND A POUNDING OF A CERTAIN PINCH POINT BE ENOUGH TO FIT A 265 85 16
WITHOUT RUNNING BOARDS BUT WITH FENDER FLARES
HOW WIDE CAN I GO USING FACTORY WHEELS WITHOUT A LOT OF RUBBING
I LIKE IT TO STILL BE ABLE TO CORNER WITHOUT ROLLING THE SIDEWALLS
AND IF ANYONE HAS ANY COMMENTS ABOUT WHEEL SPACERS FOR THIS SETUP I AM OPEN TO SUGGESTIONS I WANT THE FENDER WELLS FULL
I AM MOSTLY ON THE ROAD SO I LIKE A SMOOTH RIDE
WILL THE OME LD OR MD SHOCKS PROVIDE THIS
HOW ARE THE TIKICOS IN COMPARISON
AND WHERE IS THIS AWFUL PINCH POINT THAT I KEEP HEARING ABOUT
KEEP IN MIND I AM NEW TO THIS AND I JUST WANT TO BE SURE BECAUSE THIS IS A LOT OF MONEY TO ME.
THANKS IN ADVANCE GUYS
JEREMY
Old Jul 20, 2006 | 07:01 PM
ROOFGOOF's Avatar
Watch the 3 inch spacer on the front due to CV angles. Some with a 3inch lift experience the CVs puking. Make sure you have a differential drop kit in your plans. Maybe a 2.5 inch would be alittle safer.
I have a 2.5 inch spacer on my front with factory shocks and the ride is fine to me...you will have a stiffer ride but nothing to extreme..thats one of the effects of having a lift.
Your tires should have plenty of clearance with that lift. If you have 285-75-16's then you might have alittle rub, but a body lift would help avoid that issue. I have a slight rub on mine at goovy angles, but nothing extreme.
Alot of guys use the OME springs on the rear and tundra springs on the front...you could spend all day looking at the search results...
Good luck.
Old Jul 20, 2006 | 07:06 PM
YES I DECIDED ON THE DIFF DROP FROM SONORA STEEL
FORGOT TO ADD THAT
Old Jul 20, 2006 | 07:09 PM
ROOFGOOF's Avatar
Oh, and make sure you post some pics
Old Jul 20, 2006 | 07:24 PM
Good Times's Avatar
JEREMY:
You've got PM from me.
Thanks!
Old Jul 20, 2006 | 07:27 PM
fireteacher's Avatar
STOP YELLING!!! and welcome!!!!!
Old Jul 21, 2006 | 04:19 AM
sorry bout that
Old Jul 21, 2006 | 07:05 AM
BajaRunner's Avatar
Ouch! My ears are ringing
Old Jul 22, 2006 | 04:08 AM
does it dound like a good setup
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
