96 4 runner lift/tires/shocks setup questions
OK HERE GOES
I WILL BE USING THE TOYTEC 3" LIFT WITH THE OME SPRINGS WILL THIS SUSPENSION LIFT AND A POUNDING OF A CERTAIN PINCH POINT BE ENOUGH TO FIT A 265 85 16 WITHOUT RUNNING BOARDS BUT WITH FENDER FLARES HOW WIDE CAN I GO USING FACTORY WHEELS WITHOUT A LOT OF RUBBING I LIKE IT TO STILL BE ABLE TO CORNER WITHOUT ROLLING THE SIDEWALLS AND IF ANYONE HAS ANY COMMENTS ABOUT WHEEL SPACERS FOR THIS SETUP I AM OPEN TO SUGGESTIONS I WANT THE FENDER WELLS FULL I AM MOSTLY ON THE ROAD SO I LIKE A SMOOTH RIDE WILL THE OME LD OR MD SHOCKS PROVIDE THIS HOW ARE THE TIKICOS IN COMPARISON AND WHERE IS THIS AWFUL PINCH POINT THAT I KEEP HEARING ABOUT KEEP IN MIND I AM NEW TO THIS AND I JUST WANT TO BE SURE BECAUSE THIS IS A LOT OF MONEY TO ME. THANKS IN ADVANCE GUYS :bowdown: :bowdown: :bowdown: JEREMY |
Watch the 3 inch spacer on the front due to CV angles. Some with a 3inch lift experience the CVs puking. Make sure you have a differential drop kit in your plans. Maybe a 2.5 inch would be alittle safer.
I have a 2.5 inch spacer on my front with factory shocks and the ride is fine to me...you will have a stiffer ride but nothing to extreme..thats one of the effects of having a lift. Your tires should have plenty of clearance with that lift. If you have 285-75-16's then you might have alittle rub, but a body lift would help avoid that issue. I have a slight rub on mine at goovy angles, but nothing extreme. Alot of guys use the OME springs on the rear and tundra springs on the front...you could spend all day looking at the search results... Good luck. |
YES I DECIDED ON THE DIFF DROP FROM SONORA STEEL
FORGOT TO ADD THAT :bang: |
Oh, and make sure you post some pics :D
JEREMY:
You've got PM from me. Thanks! |
STOP YELLING!!! and welcome!!!!!
sorry bout that
Ouch! My ears are ringing :(
does it dound like a good setup
