91 4 runner 22RE hesitation
Old Aug 4, 2003 | 05:29 PM
hotshot's Avatar
Question 91 4 runner 22RE hesitation
I have a 91 4runner with 22RE and automatic trans. It hesitates when i punch the accelerator. It does it more when its cold, but keeps doing it even after it warms up. I changed plugs and wires which made no diff. When I advance the timing to where it pings then the hesitation goes away and it seems to have a little more power.
Anybody knows the problem might be?
Old Aug 4, 2003 | 06:41 PM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
1. fuel filter
2. injectors
3. check valve lash
4. clean throttle body/ check air filter
5. turn 3 times and whisper "ali shabaz" toward engine
Those are the first things I would scope out... maybe someone else will chime in and give a few more suggestions.
Old Aug 4, 2003 | 06:42 PM
flecker's Avatar
Oh, check the o2 sensor/ sensors as well, do you get a check engine light?
Old Aug 4, 2003 | 10:04 PM
AgRunner06's Avatar
Post TPS
I bet the problem is a bad or misadjusted TPS. Here is a great site on the TPS. At the bottom of the page it describes the symptoms. Hesitation is listed there.
Good Luck
Old Aug 5, 2003 | 10:40 AM
hotshot's Avatar
no code
Engine Light never comes while driving and no code is stored. My guess would be if the tps was out it would have a code.
I have also thought it might be the injectors. I will flush them one and see what happens.
Old Aug 5, 2003 | 10:56 AM
flecker's Avatar
Actually AgRunner has a good suspect as well... The tps out of adjustment wouldn't throw a code/ check engine light. In my experience w/ 22re I always check fuel filter first on hesitation, and back the timing off... you don't want all that pinging
Old Aug 6, 2003 | 10:12 AM
hotshot's Avatar
Oh yes I changed the fuel filter but not diff. I think its running lean especialy at idle. I read up on the temp sensor and I think its probably the problem. Also I will flush injctors.
Thanks for the help
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
