88 4Runner V6 problem
Old Jan 2, 2004 | 08:31 AM
DocLo's Avatar
Hey, I'm new here. My name is Jason and I was directed here by Kyle (my99).
I bought an 88 4runner a couple of months ago (auto 3.0L V6 w/175k). About 6 weeks ago I had a problem keeping it running. I went out one day and tried to start it (had been running fine the day before) and it turned over many times before it would kick on. When I put it in drive or reverse it would die. I figured it was having trouble getting fuel and it probably needed a new fuel filter so I'd try that first. Well, I don't really know if the problem fixed itself or if it really was the filter, but it worked.
So, I go out yesterday morning and get the same problem, but this time it won't even run in park or neutral like it did last time. When I stop turning the motor I get a little putter, but that's it. It seems to be getting air and spark. Could it be the fuel pump? As a side note, it's been very moist the last couple days, I dunno if that would have any bearings on the situation.
Any help is appreciated.
Old Jan 2, 2004 | 08:44 AM
rimpainter.com's Avatar
It could be the fuel pump, but your best bet is to diagnose the problem (what you are trying to do) instead of replacing a bunch of parts. If you do not have the FSM and the proper tools, it might just be worth the $40 or so to have the problem identified. Then, if you agree with the diagnosis, you can tackle the replacement part if you feel comfortable.
Did the 88 3.0 have a headgasket problem like the later models?
Old Jan 2, 2004 | 08:48 AM
My99's Avatar
$40? However long it takes them to find the problem is what it will cost, plus whatever they "think" it needs in order to be fixed. I said perhaps fuel pump, but lets see what other 3.0 guys think it might be.
Old Jan 2, 2004 | 08:49 AM
amusement's Avatar
Re: 88 4Runner V6 problem
Kyle its an easy fix. Looks like the fuel pump (fuel injection) relay(s) are failing you. On my 95 there were 2 relays had to replace.
I think your 88 has only one that is located under the hood in the fuse box. If there was a second it would under the dash about where the key lock is located.
I think it was $17 or less each.
I got my '95 cheap because the people who used to own it couldn't figure out why the pickup wouldn't start or stalled at different times. I tinkered around with the idea of a failing fuel pump but, replace the relays instread. I have been running great for over 60,000 miles.
Old Jan 2, 2004 | 08:55 AM
Not at an independent shop. Some will diagnose for a flat fee.
Yeah, I realize that there are additional costs to order parts, thanks for pointing that out.
Old Jan 2, 2004 | 09:12 AM
DocLo's Avatar
I'll be damned. I went out to tinker with it and tried to start it for ˟˟˟˟sngiggles and it fired up. About an hour ago, I was getting nothing. It doesn't stall when I put it in R or D either. Could it still be the relay?
Old Jan 2, 2004 | 09:15 AM
Yes it could. Fuel pumps and relays can work intermittently before they crap out for good.
Old Jan 2, 2004 | 09:35 AM
amusement's Avatar
Doclo I ain't no betting man, but I would bet it is the relay.
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
Flightguy
Oct 2, 2015 05:34 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
EatChipsNow
Sep 9, 2015 01:25 AM
