81 lockouts What works??????????
Old Nov 23, 2003 | 08:03 PM
Question 81 lockouts What works??????????
I need a new set of hubs on my '81. How new can I go? Is there a spline difference? I'm not an extreme off-roader but depend on them to work. Anyone have a set to part with?
Old Nov 23, 2003 | 08:12 PM
toy283's Avatar
Any set from a solid axle truck or 4Runner ('79-'85) will work. You cannot use IFS hubs, they are 26-spline yours are 30-spline.
Old Nov 23, 2003 | 08:56 PM
kyle_22r's Avatar
the only differences that you will see from '79 to '85 is that '79 and 80(possibly 81) have blue dials on the hubs and say "ASCO" instead of "AISIN". they're really the same, though
Old Nov 23, 2003 | 09:58 PM
jjdeneen's Avatar
i got an 80
i bought some WARN hubs for $140
Old Nov 24, 2003 | 01:04 AM
toy283's Avatar
I'm sorry. Just be sure to keep the nuts tight.
Reasons Warn hubs are generally considered inferior to Aisins:
1. Lack of cone washers. The nuts holding the Warns on tend to loosen in time. The result can be sheared studs. BTDT.
2. Cost. A set of Warn cost $140, Aisins run about half of that at the junkyard. BTDT.
3. Aisins are much easier to rebuild/fix. Try buying a replacement spring or cap for a Warn hub, a replacement Aisin part is avaialble from your local dealer. They may not have it in stock but you will have it faster than a comparable Warn part. BTDT.
4. Profile. Warn hubs stick out ~1" further than Aisins. A serious issue on the rocks, less so in mud.
5. Inferior Construction materials/methods. The Warns are made of a lower grade steel and the castings are thinner. End result: grenaded hubs. BTDT.
Old Nov 24, 2003 | 09:33 AM
Thanks for the help. Anyone have a set of factory hubs to sell???????????????????
Old Nov 24, 2003 | 07:26 PM
Is there any where I can get service parts for my AISINS? I would put the money into them if I could. The cam is completely gone on one side. I can get gaskets. Also what is the best lube for the hubs.
I am only a recent member to this site and I must say, you guys are great! I've been a TOYOWNER for over 15 years. I bought a 4 short box in 86 Then traded up for a 90 4 runner Also owning at the same time a 79 and an 81 pickup Then I sold that for a new 95 Chevy Silverado.( BRAIN F@RT!) That lasted 8 months and I went screaming back to toy's and haven't left since. I bought the first rusted-out 87 x-cab I found then moved into a 92 x-cab. I trade that in for a 98 Tacoma then Bought a roll-over 96 4runner. That was going to be for my wife. I couldn't give it up so I traded the 98 Tacoma for a 99 4runner for her. And last winter we moved her into a 01 sequoia. Then 2 months ago I had the chance to get another 81 longbox. But I had to sell my 76 280Z to get it in the house peacefully. (ALL 4X4's)
Thats not all. I have infected my family into TOYO-HOLICS. Dad had a pathinder then I talked him into a 92 landcruiser he then sold his F150 for a 96 T100 Add to that moms 91 then 99
LS400's and dad tipping up to a 99 LX470 and a 2000 Tundra. Then selling his 90 300ZX for a 04 SC430.
I have one brothe that will drive his 95 T100 into the ground (literally) and My nephews and a niece in G3 4Runners And my sister is now in a 03 Seqoia.
Old Nov 24, 2003 | 07:35 PM
Plays_with_Toys's Avatar
Welcome aboard! I think you will find most everyone here is good people. Don't be afraid to ask a question, its always best to use the flashing green button of enlightenment above, but if you can't get results, post away.
Seconding the question about lubrication. And not to jack the thread, but what is the best trick for making sure they don't freeze in winter? I once read about graphite lubricant or spray???
Old Nov 25, 2003 | 08:38 PM
Serith's Avatar
Yea thats what i have heard works too. I'm in the process of trying to buy a new Aisin hub myself for my 83'. Just call around the local junkyards and ask. I dont know of anywhere that sells them new other than maybe the dealerships, which will charge you way to much.
Old Nov 25, 2003 | 09:35 PM
kyle_22r's Avatar
marlin sells them for 75$ a pair used...i'll remember that when i do my full floater in the rear
Old Nov 25, 2003 | 09:57 PM
toy283's Avatar
If you're gonna go full-floating, why not use a set of FJ-80 drive flanges? Much stronger. Unless you want the lockout for flat-towing?
Old Nov 26, 2003 | 12:35 PM
kyle_22r's Avatar
that was kind of my idea there...being able to lock/unlock the rear hubs. i wouldn't mind using the flanges though, since it would could be a pain having as mischevious friends as i do
Old Nov 28, 2003 | 10:00 AM
Is there any website that has an exploded view of the AISIN hubs? Just so I know what I exactly need.
Old Nov 28, 2003 | 11:10 AM
kyle_22r's Avatar
http://www.cascadecrawlers.com/toyot...ld/index.shtml
that should explain what to get. you'll need the hub body, the cover, the guts and all the hardware(cone washers, nuts etc). there's a diagram of all the parts a little ways down
it shows how to rebuild them, which is pretty easy and a good idea before you install them
Old Nov 28, 2003 | 08:31 PM
thanks Kyle
Old Nov 28, 2003 | 08:58 PM
kyle_22r's Avatar
glad to help
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
