7MGTE Swap
Old Dec 7, 2004 | 03:52 PM
YotaTruck1986's Avatar
Question 7MGTE Swap
I've been doing some researching on the 7MGTE Swap and found some pretty good info. There's EngineWholesalers.com that have a 7MGE for about $600 and 7MGTE for $1000. Besides the motor what else would have to be replaced in an 86 2WD Pickup (22RE, 5 speed). I beleive the transmission is a W56. Would you have to replace the exhaust, bell housing, ECU, wiring harness, and radiator? They say they give you the distributor. Would I have to replace the alternator? What about A/C? Sounds like I'd probably be better off just buying an old Supra.
Old Dec 7, 2004 | 04:03 PM
Scratch that about EngineWholesalers.com. Looks like JMDSource.com has it for $750. Plus it includes ECU, transmission, and wire harness. Any opinions?
Old Dec 7, 2004 | 05:13 PM
ZeroYota's Avatar
A quick Google search found this. Swap
Good luck with your project.
Old Dec 7, 2004 | 05:18 PM
Yeah, I've visted that site. 12 second pickup, that's a fast toy.
Old Dec 7, 2004 | 05:36 PM
turboale's Avatar
There is a guy here in asheville that had a POS truck... i mean... horrible paint, not to mention its condition but also the color (mix between puke yellow and doodoo brown) anyway... he had the older model supra turbo engine in it and he wooped my buddys chipped 02 S4. THAT was a suprise! He said he was out the door $3,500 and did all the work him self... sounds like a good deal to me
edit:that included the truck...
Old Dec 7, 2004 | 05:43 PM
ekim121's Avatar
Someone on here has a page that talks about everything they did for the swap...it sounded pretty labor intensive. If you know what you're doing in terms of fabrication and such it'd be awesome, so good luck if you do it...
Old Dec 7, 2004 | 06:03 PM
kyle_22r's Avatar
supra engine is a good swap candidate. my only concern would be the oilpan contacting with your IFS, but it might not since 2wd trucks have a mid sump pan...
the engine should bolt to your mounts with 5MGE mounts IIRC(may have to drill the holes out a little bigger on the mount). it'll bolt to your truck's tranny with the supra bellhousing but why bother? supras had the W58 or R154 which are both stronger and since you have a 2wd they will probably bolt right in
Old Dec 7, 2004 | 06:12 PM
I'll probably just end up jumping on the import tuner bandwagon.
Old Dec 7, 2004 | 06:19 PM
rimpainter.com's Avatar
That's what I did until I got a bunch of tickets and in a bunch of trouble. You remind me of someone I used to know quite well in fact...
just skip all the in-between and get a 3rd gen 4x4. You'll be back anyway if you get into import tuning. Just start now.
Old Dec 7, 2004 | 06:27 PM
Don't have to worry about ever getting rid of my Pickup. It's not going anywhere, ever. It's been passed down over the generatiosn so there's no chance of it leaving. Plus, who could sell a Toyota ? Anyway, if I do end up getting a tuner, I will definitely turn my street truck into an off road truck. Which I've been wanting to do, but I don't want to loose the little bit of speed it has now.
Old Dec 7, 2004 | 06:29 PM
UKMyers's Avatar
Goto www.supracharged.com for a lot of good info on swapping these engines into Toys.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
