75w/90 vs 80w/90 in the REAR dif...
In trying to find Mobil 1 gear oil around here....no one has it in 80w/90
only 75w/90 -
am I cool to run that in the rear dif? I'm in MO...it DOES get pretty cold here....and I did notice the write-up on BOBSR5's site says 80w/90 in the rear....so??
suggestions?
thanks,
aaron
only 75w/90 -
suggestions?
thanks,
aaron
only 75w/90 -
suggestions?
thanks,
aaron
only 75w/90 -
suggestions?
thanks,
aaron
I'm running Amsoil 75W-90 in the Front/Rear Diffs, Transfer Case, & Manual Tranny. No problems what so ever. Shifts much smoother in the winter with this Gear Lube.
I'd say do it!!! Best of Luck
Andrew
only 75w/90 -
suggestions?
thanks,
aaron
only 75w/90 -
suggestions?
thanks,
aaron
http://intershop.amsoil.com/cgi-bin/...0/Catalog/1110
Bob's write-up says he used this Amsoil 80w/90 (AGL-QT), which you can find on the above link for 7.65 / qt
only 75w/90 -
suggestions?
thanks,
aaron
only 75w/90 -
suggestions?
thanks,
aaron
Not to hi-jack the thread, but can you just switch to the synthetic stuff w/o a problem? I know in motor oil there are problems sometimes.
Also, how did y'all get those darn fill and drain plugs off? I think they are 24mm, and I've been PB blastin um, but they are not budging.
Ok, well now I feel better. I was feeling like the govenator says "a girlyman" I tried being nice and asking the plugs to exit the holes, yet they are not listening. I guess it'll be no more Mr. Nice guy and I'll have to break out the Impact wrench and get some replacements just in case!
I changed mine today.
I used Valvoline High performance 80/90 gear oil.
I also put some Nulon addititive in the auto trans as well for the hell of it,& it made quite a differance . I need to get the auto flushed soon as it getting a bit stiff & noisy, but i was amazed how well that stuff works on my tired old transmission.
Originally Posted by nunsa
I run the RedLine Heavy Shockproof Oil in my Front & Rear axles and the Redline Mt-90 in my tranny & transfer. Great stuff!
Originally Posted by Nolan
were you able to find your redline locally or did you have to order it online? Just wondering because I have never seen it stocked.
Redline Gear Oil info
Don't pay more than $8/qt. for it either.
Originally Posted by 4Crawler
Its usually available locally, check Redline's dealer page. I found a local race shop that sells it cheap, especially if you get a case. My local Toyota dealer carries it, too, as do many of the local (non-chain) auto parts stores.
http://www.redlineoil.com/dealers_re...37&submit.y=10
I bought the Redline online at www.summitracing.com , I think it was $8 something, a real good price!
kirkrunner
07-27-2015 07:59 PM
Athansinis
07-27-2015 08:38 AM
icentropy
07-14-2015 10:23 AM
