4Runner runs poorly, drinks gas
Old Mar 6, 2007 | 08:33 PM
BruceTS's Avatar
my vote is the sparkplugs............
Old Mar 8, 2007 | 04:38 AM
Bass Player's Avatar
I'm ready to cut my losses and trade this damn thing in. Today we replaced the front O2 sensor, the plugs, and the plug wires. Rebooted the computer, and it runs exactly the same. Idling at 500 rpm with no Check Engine light. One thing we figured out is that if you rev the engine in Park, the timing advances. If you shift into Drive and power-brake it, the timing retards.
Old Mar 8, 2007 | 05:21 AM
gpcollen1's Avatar
Replacing the A/F and O2 is spensive just to do it for kicks without determining they are bad. I am fighting through some issues and more and more getting pointed to my injectors. I would get teh final diagnosis before just changing out $1000 in parts.
Old Mar 8, 2007 | 05:25 AM
Chapman88SR5's Avatar
Originally Posted by seanz0rz
ruth
make sure you use denso plugs too... just thought id throw that out there.
if you do replace the o2 sensor ( i dont think thats your problem...) replace with only with a denso from toyota, dont use others
check if you have good spark too. might be the coils are going. have you checked timing?
What if he didn't use Denso plugs? My girlfriend had her truck in the shop and they replaced her plugs with Champion or something.
Old Mar 8, 2007 | 05:26 AM
  #25
midiwall's Avatar
What do you know about the history of the truck? Was it abused at all? Have you done anything like a leak-down test or compression test?
http://www.type2.com/library/engineg/leaktst.htm
http://autos.yahoo.com/maintain/repa...ques057_1.html
You can also do a simply test with a tissue or paper towel... Start it up, let it idle, take a tissue and hold it about an inch from the tailpipe. it should only be blown away from the pipe. If it looks like it's getting sucked in, you've got a stuck/burned valve.
Old Mar 8, 2007 | 05:47 AM
  #26
I'm working with 2 excellent mechanics, we aren't doing this "for kicks", and I haven't spent nearly $1000. Believe me, I have better things to do with my money. Most of the parts we've replaced have been maintenance items anyway.
Old Mar 8, 2007 | 06:23 AM
  #27
rdharper's Avatar
Hi Mark. I assume you've actually seen this occur with the tissue test? I'd trust that, but I must admit that it is hard to believe a non-functioning exhaust valve would actually create a negative pressure strong enough to overcome the other 5... strong enough to reverse the flow in the entire exhaust.
Of course I'm speaking only "theory" here. Maybe you'd get a momentary reduction in the postive pressure, enough to make the tissue pull back from the positive pressure appearing as kind of vibration in the exhaust pressure.
Anyway, a cute idea. And easy enough to try.
Old Mar 8, 2007 | 08:38 AM
  #28
gpcollen1's Avatar
Glad to hear that!
Old Mar 8, 2007 | 08:48 AM
  #29
kmchby76's Avatar
Have you tested the fuel injectors? It a pretty easy test. What do you have to lose? Take an Ohm meter and see that the injectors are around 13-16 Ohms.
Old Mar 8, 2007 | 08:52 AM
  #30
crazy_horse3030's Avatar
Break down...go to Toyota Dealership...pay 70 bucks and let them diagnose the problem with their computers. Then take it somewhere else to get it fixed.
Old Mar 8, 2007 | 08:57 AM
  #31
I don't know if that was done or not, but I'll ask.
Old Mar 8, 2007 | 09:24 AM
  #32
midiwall's Avatar
Oh yeah... DD showed it to me on my truck before we tore it down. It's pretty clear - much more than you would think.
But in the end, a leak-down will be a much better indicator.
Old Mar 8, 2007 | 06:01 PM
  #33
BruceTS's Avatar
time for a compression test and as stated leak down test.
your gonna have to start narrowing down the field
If compression is fine and leak down are within specs, then check fuel delivery system. Are the injectors working properly. If those are ok next check for proper spark. etc etc
My biggest concern is the history of the vehicle. Especially the engine what it went through. I currently have a 3.4L engine sitting my garage that is toast because of a lean out condition from having a supercharger on it.
Old Mar 19, 2007 | 11:06 AM
  #34
Talking Success at last!
Well, I finally got my 4Runner fixed! I took it to another mechanic on a friend's recommendation (mine had given up), and he diagnosed the problem immediately. He said he could tell what it was as soon as he drove off in it. The problem was with the lower timing belt sprocket. The keyway had "walked" as he put it, and was gradually widening the slot. Because of this, the timing read OK at idle, but jumped all over the place when you put any load on the engine. He said he'd only seen this a couple of times, and those were with Camry 4-cylinders. So dusty98 was on the right track, even though the belt was OK and had not slipped. The first mechanic said he thought it was a timing issue, but he would have never suspected the sprocket, and that he had never seen that happen.
Anyway, as soon as I turned the key, I got a big smile on my face. It runs great now! Gobs of power, smooth as silk, and MPG went from 9 to 18. He also found that the rear brakes were hanging because of gear oil leaking due to bad axle seals. He went over the whole truck, lubing and adjusting everything in sight. The thing drives like a completely different vehicle. I'm a happy boy. Thanks to all for the suggestions!
Old Mar 19, 2007 | 11:10 AM
  #35
mkgarrison5's Avatar
sweet
Old Mar 19, 2007 | 11:41 AM
  #36
Marley2984's Avatar
I love when a plan comes together
Old Mar 19, 2007 | 12:00 PM
  #37
MTL_4runner's Avatar
That was probably a leftover from a timing belt that wasn't done properly (ie improperly torqued).
You're very lucky you caught that early because it could have been ALOT worse!
https://www.yotatech.com/forums/f2/help-my-crankshaft-pulley-wobbelin-79429/ (this is probably what yours looked like)
https://www.yotatech.com/forums/f116/lesson-learned-pics-76293/
https://www.yotatech.com/forums/f2/crank-pulley-wobble-88872/
https://www.yotatech.com/forums/f2/crankshaft-bolt-felt-out-bye-bye-crankshaft-89038/
https://www.yotatech.com/forums/f2/crankshaft-pulley-came-off-help-65946/
https://www.yotatech.com/forums/f2/3-4l-engine-problems-37150/
https://www.yotatech.com/forums/f2/help-harmonic-balancer-16920/
Old Mar 19, 2007 | 12:23 PM
  #38
MTL, that's exactly what mine looked like.
Old Mar 19, 2007 | 01:53 PM
  #39
Epic Ed's Avatar
That's the first time I've heard of that problem. I never would have guessed. Glad that someone finally found a resolution.
Ed
Old Mar 19, 2007 | 02:11 PM
  #40
rdharper's Avatar
Cool thread... I wonder if there is anyway to catch this "in the driveway" as opposed to have an ace mechanic in your pocket.
Hmmm.... maybe not.
voiddweller
19
May 2, 2016 09:10 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
serenity03k64
Jun 27, 2015 07:59 AM
WI Girl
Jun 25, 2015 03:45 AM
crazypaint
Jun 23, 2015 03:27 AM
