4runner passanger windows issue
Old May 9, 2004 | 10:28 AM
dogcarrier's Avatar
Angry 4runner passanger windows issue
I have a '95 4Runner, V6, limited.
I replaced the positive side of battery terminal without issue, but after doing this the passanger windows will not roll down from the master control on drivers side OR from their own individual buttons. Bottom line is that drivers side window is fine, sunroof is fine, back window works WITH THE KEY, but not from inside. All fuses have been checked and are fine, even the hidden one that has to do with power windows. I am lost here, no clue.
Thanks to anyone who responds,
Nathan
Old May 9, 2004 | 03:09 PM
gwhayduke's Avatar
Check the child-proof safety switch in the master panel. I'll bet a dollar to a doughnut that it's engaged. :pat:
Old May 9, 2004 | 07:28 PM
where is this childproof safety switch that you speak of?
Old May 10, 2004 | 08:31 AM
dogcarrier's Avatar
Unhappy bonehead award, I owe doughnuts
Well, that was it, thank you for the pointer, not feeling too bright right now.....
Thanks again....
Old May 10, 2004 | 01:35 PM
dogcarrier's Avatar
location of child lock on 95 4runner
It is in the master controls for all windows on the drivers side door.
Old May 15, 2004 | 11:14 AM
WIZARDOFODDZ's Avatar
Nathan
May I ask where this so called hidden fuse is located?
I'm also having window problems
Old May 15, 2004 | 07:09 PM
User 051420's Avatar
I've hit that button soooo many times, and got REALLY mad when the rear window wouldn't go up!! GRR!
Don't feel too bad, you aren't the only one!
Old May 18, 2004 | 03:34 PM
dogcarrier's Avatar
location of window fuse
Sure, that fuse (on a 95 3.0 V6 limited) is toward the firewall right next to the other fuses on the drivers side kick panel. You have to take the panel off with a little hand-turn screw and then it is hiding way back there, it is one of those square fuses and it controls all windows and door locks. Hope that helps.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
