4Runner Body Lift?
Old May 14, 2005 | 09:19 PM
quivvy's Avatar
4Runner Body Lift?
Do they sell body lifts for 4runners from 86-95? i cant find them for a automatic trans for some reason. maybe im tarded and its late and i aint searchin right. can someone help me out?
Old May 14, 2005 | 09:24 PM
4Crawler's Avatar
You bet:
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Old May 14, 2005 | 11:40 PM
Fink's Avatar
I am personally recommending the above member and his products...very nice stuff, you will NOT be disappointed!
Fink
Old May 15, 2005 | 12:00 AM
jimbo74's Avatar
i will also vouch for 4crawler stuff... roger is a good man, and his 4crawler stuff is awesome...
Old May 15, 2005 | 07:39 AM
quivvy's Avatar
good to hear. im lookin to do a 1" and 33"s so it will be liveable as a DD (i run work out of it) and have some fun on the trails on the weekends.
Old May 15, 2005 | 07:44 AM
4Crawler's Avatar
For 1" lift, you won't need to use any A/T brackets:
http://www.4crawler.com/4x4/ForSale/...l#Applications
http://www.4crawler.com/4x4/ForSale/...BodyLift.shtml
Old May 15, 2005 | 09:31 AM
HOJU's Avatar
definetly get a RB body lift..... they rock, took me 2 hours to put mine in-
Old May 15, 2005 | 11:32 AM
quivvy's Avatar
would it make more sense to do a 1" BL and 33"s? (will it rub bad or will some trimming remedy it?) or a BJ spacer up front and either springs/spacers in the rear to level it out?
Old May 15, 2005 | 11:44 AM
4Crawler's Avatar
There is a long list of options on this part of the web page:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Usually 1" body lift alone is not enough to fit 33s, you'll either need to crank up the torsion bars, swap to stiffer bars, or add a ball joint spacer up front and do something in back to level it out. Read the various links on the page above for some ideas.
A lot of it depends on your goals for the lift, your budget and your aversion (or lack thereof) of trimming fenders as well as the exact wheel and tire combo you want to run. For a budget lift, 1" body, cranked t-bars, something for the rear end and trim until it fits. For added suspension travel and a better ride, do the spacers up front. You could always add them later as you see fit.
Old May 15, 2005 | 11:45 AM
jimbo74's Avatar
you are going t oget differtn opinions on this issue, but i would say go as big as possible because it is not going to throw your center of gravity off much more with a 2" than it will with a 1" and most vehicles have differnt manufacturing tolerances meaning that a 1" bl with the same suspension and tire setup on runner A might not rub but on runner B the 2", still rubs.....
Old May 15, 2005 | 12:30 PM
quivvy's Avatar
my goals are for a DD and some trail rides 1-2x a weekend. obviously id like some good flex but i dont know how good i can actually get with such a tight budget and the amount of lift im lookin at, given a BL wont increase flex at all. thanks for all the input guys, id like as much as i can get.
Old May 15, 2005 | 12:46 PM
4Crawler's Avatar
Then the 1" body + cranked torsion bars is probably what you need. See the link to the '94 pickup with exactly that combination on the web page posted earlier. Has a link toa full article on the truck with on-trail photos and all.
Old May 15, 2005 | 02:10 PM
02Runner's Avatar
Another one to vouch for Rogers work.
Doug.
Old May 15, 2005 | 03:44 PM
r0cky's Avatar
And another!
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
