3rd Gen Front Trim removal
Old Jul 3, 2010 | 04:51 PM
redhawk427's Avatar
im trying to remove the front, chrome, trim piece so that i can paint it but these clips have me stumped. i dont wanna go and break them so does anyone know an easy way to remove this piece? i attached pics of what im talkin about
Attached Thumbnails 3rd Gen Front Trim removal-trim-i-wanna-remove.jpg   3rd Gen Front Trim removal-clip.jpg
Old Jul 3, 2010 | 05:50 PM
Ritzy4Runner's Avatar
In each of the clips that holds the grill in place is a small tab. You should be able to slip one of the ends of your fingers in from the side. I beleive the center post is from the front and all you need to do is lift that tab up so that it aligns with the slot in the post It usually will make a slight 'pop' sound and the grill will move a bit forward if you pull gently on it. Do that to all the post/standoffs. I think there are like 7 of them? If you do happen to break one off, the others will hold the grill in place. I picked up an all black grill off a 2000 limited that was missing like3 clips but I was still able to pop it on and it stayed just fine. Try a search on Grill Removal and you should get several hits. Not hard once you figure out what you need to do, I can get mine off in under 5 minutes
Old Jul 3, 2010 | 05:56 PM
redhawk427's Avatar
worked perfect thank you!
Old Jul 3, 2010 | 07:47 PM
redhawk427's Avatar
got it done, this pic kinda sucks but oh well
Old Jul 4, 2010 | 10:36 AM
pendrag's Avatar
The little suckers are poorly designed and don't hold up well to heat and time, in my experience.
You can purchase them on Amazon.
Old Jul 4, 2010 | 10:31 PM
Da808racer's Avatar
From: From Honolulu, Hawaii, currently in Beaverton, Oregon.
Speaking from experience, after you get the grill out, pull those little clips off the vehicle and clip them onto the grill before you snap it back in...beats the heck out of leaving the clips on the vehicle and then trying to line them all up perfectly. Seems so obvious AFTER you spend a few frustrating minutes trying to line that bugger up!
Old Jul 5, 2010 | 07:56 AM
pendrag's Avatar
That's a good tip that works well.
Old Jul 7, 2010 | 08:33 AM
Mauzer's Avatar
Does anyone have pics of the BACK of a pre 99' grill? I've been thinking of doing the Satoshi mod but wanted to get a pre 99 grill to do the mod on so I can swap grilles out if/when I bust one. Basically I wanna know if the 96-98 grill will fit an 02?
Old Jul 9, 2010 | 03:26 AM
awpsome's Avatar
i broke all those clips but nothign some zip ties cant fix
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
coryc85
Jul 6, 2015 04:07 AM
