3.4 Idle adjustment
Old Apr 19, 2006 | 10:59 AM
MorphiasX's Avatar
3.4 Idle adjustment
I was wondering how to adjust the idle on a 3.4 V6. I just swapped one into my truck, and its running fine, but seems to idle a bit high. On my 3.0 you would just adjust the distributor, but the 3.4 is distributorless, and is timed by the position of the timing belt, which cannot be adjusted. Is it computer controlled and cant be changed?
Old Apr 19, 2006 | 11:11 AM
DavidA's Avatar
If I remember correctly the adjustment screw is on the throttlebody.
MTL_4runner's Avatar
Yes. There is likely a reason for it idling high, but it will take a bit of work to find the cause.
Old Apr 19, 2006 | 11:17 AM
rimpainter.com's Avatar
A couple ideas to check since this is a computer controlled feature:
1. Idle-up feature of the A/C when engaged.
2. Throttle cable
Jamie's right though, this is going to take some time to track down.
Old Apr 20, 2006 | 07:48 AM
AK95Taco's Avatar
Just to clarify, there is NO mechanical idle adjustment on the 3.4. It is a computer controled function.
Old Apr 20, 2006 | 09:33 AM
ugadawg95's Avatar
Ditto to what AK9 said. There is no adjustment.
Old Apr 20, 2006 | 12:49 PM
MorphiasX's Avatar
So there is no screw on the throttlebody like DavidA said?
Old Apr 20, 2006 | 12:59 PM
DavidA's Avatar
I thought there was a screw adjustment on the throttlebody spring?
Old Apr 20, 2006 | 02:26 PM
On a 3VZ (3.0L), yes, there is one.
On a 5VZ (3.4L), no there isn't one.
The ECU uses the IAC valve to control idle on the 3.4L
.....which might be something to look at for this high idle condition.
Old Apr 20, 2006 | 04:32 PM
profuse007's Avatar
check for vacuum hoses.
Old Apr 20, 2006 | 06:10 PM
IS3004Runner's Avatar
May I ask where is the IAC valve? sometimes, my truck is idling around 600 rpm on drive with my foot on the brake, i can feel vibrations on the seat. I have to put it in neutral as it gets annoying sitting on the traffic. once in a while it idles at 750 rpm, which is the desirable engine idle speed.
Old Apr 20, 2006 | 07:37 PM
MorphiasX's Avatar
Also, the idle surges. It will be running a little high, then for a split second drops to a lower rpm (one that is a little more desireable) then back to the higher rpm. I havnt done the resistor mod to my tach yet, so im not sure of the actual RPM as of yet.
Old Apr 21, 2006 | 09:08 AM
You probably just need to give your throttle body a good cleaning to get it back to idling well again. I don't know what kind of maintenance you have done, but you should also change the air and fuel filters, plugs (OEM Densos or NGKs) and clean the MAF while you are in there. The IAC can be cleaned but it is a bit of a pain to do and most of the time the other items are the ones causing the low idle.
http://www.4x4wire.com/toyota/mainte...tenancep5.html
Old Apr 25, 2006 | 03:25 PM
kode3's Avatar
This is what my 2001 is doing, I posted about this but and have changed the spark plugs and fuel filter with no change.
Old Apr 25, 2006 | 05:12 PM
Did you clean the throttle body yet?
Old Apr 25, 2006 | 06:17 PM
kode3's Avatar
I sure did, I used FI Throttle Body cleaner from Napa.
Old Apr 26, 2006 | 04:45 AM
Ok, then if you are still having issues with the idle dropping too low then you might want to try cleaning the IAC valve too.
Keep in mind the idle will drop by about 100 rpm when the AC (or windshield defrost) comes on.
Alex Bessinger
Aug 31, 2015 09:17 AM
93toyoguy
Aug 2, 2015 07:41 PM
kirkrunner
Jul 27, 2015 07:59 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
