2001 3.4 Tacoma w/Rough Idle
Old Apr 25, 2006 | 12:14 AM
kode3's Avatar
Question 2001 3.4 Tacoma w/Rough Idle
OK, so here's the story. I just bought a 2001 Tacoma with the 3.4 V6 and I have since seafoamed it twice with great results, and I have changed the oil with Mobil 1. I also cleaned the MAF and throttle body, but since I picked it up it has had a rough idle only when in gear. It has 56,XXX miles and I don't have any service records for it. Would it be possible that the spark plugs would need to be replaced?
Any input would be great.
Thanks!
Jesse
Old Apr 25, 2006 | 02:39 AM
Beartracker's Avatar
Reset the computer, check your plug wires,replace plugs, replace fuel filter and air filter. All of these are inexpensive . Also forget about Seafoam and use Techtron,Seafoam is cheaper and it works but no where near as well as Techtron in the gas tank every now and then.
Did all this to my 01, 2.7 at around 60,000 and it runs like new to this day and it's real close to 80,000.
Are you running stick or auto? Not quite sure about the rough idle in gear but I have no doubt that someone on here knows what the problem is. Mike
Old Apr 25, 2006 | 10:15 AM
Thanks!
Jesse
Spark plugs (stock ones) needs to be replaced every 30K. So I would do that for sure.
Old Apr 25, 2006 | 01:24 PM
kode3's Avatar
So I changed the plugs and the fuel filter today with Toyota parts and the problem is still there, any more idea's?
Old Apr 25, 2006 | 01:59 PM
Have you checked to see if it's throwing a code? Go out late tonight and raise the hood, see if you can see any sparks anywhere from bad plug wires or any bad wireing.
Old Apr 25, 2006 | 03:57 PM
kode3's Avatar
I have seen if it is posting a code, but I thought it would have the check engine light on if it was doing that. Am I wrong?
Old Apr 25, 2006 | 11:58 PM
youngbuck's Avatar
Make sure all vacuum hoses around the throttle body are connected securely. This is a common reason for your symptoms.
Old Apr 26, 2006 | 02:49 AM
No, your light will not always come on.When there is a problem it's time to check it.
I really thought you would get more replies by now from some of these guy's who know a whole lot more than I about this kind of problem. Mike
Old Apr 26, 2006 | 05:30 AM
MTL_4runner's Avatar
I think there are 2 threads going on at the same time for this issue:
https://www.yotatech.com/forums/showthread.php?p=885762
93toyoguy
Aug 2, 2015 07:41 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
mengquis
Jul 13, 2015 10:39 AM
94whiterunner
Jul 12, 2015 07:15 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
