? for 2nd gen owners
Old Aug 25, 2004 | 01:19 PM
Sbrut95's Avatar
Im just curious if my 4Runner is abnormal. It doesn't get too cold at night here, But if I dont let my truck sit and warm up for a good 3-5 minutes in the morning, it doesnt want to drive right. Its jerky when starting out in 1st and the clutch feels like its not doing its job. Only after about a minute or so of driving does it "warm up" and then it drives fine and smooth. Does anybody else have this problem?
Old Aug 25, 2004 | 02:10 PM
flyAddict's Avatar
You're not alone. Check out this thread. Clicky
Old Aug 25, 2004 | 03:04 PM
Waterboy's Avatar
Mine does the same thing. I just let it warm up until the idle drops then its not as bad. But if I have to take off within the first minute it boggs down and gets choppy as I release the clutch. My solution: park facing slighty down hill and let momentum take care of the initial take off.
Old Aug 25, 2004 | 07:24 PM
gwhayduke's Avatar
I don't have that problem guys. I'm wondering if your cold start injector needs cleaning.
Old Aug 25, 2004 | 07:31 PM
Scofco's Avatar
Mine also has never done what is being described.
Not even in -45.
Old Aug 25, 2004 | 07:37 PM
UKMyers's Avatar
My clutch hops a bit in the morning when it's cold but it runs smooth.
Old Aug 26, 2004 | 05:52 AM
Sbrut95's Avatar
So it sounds like it could be a Fuel injection problem or Fuel pump.
Well, I just wanted to see if I was the only one having this problem. I can live with it. Its probably not a bad thing to let it warm up anyways. Thanks for the replies!
Old Aug 26, 2004 | 06:00 AM
Astralplane's Avatar
My cold start sputter was caused by a bad head gasket (#6 cylinder).
It would barely run for the the first 3 minutes then after that it run fine.
Also it wouldn't idle high when first started cold.
I was losing coolant but my compression was fine.
Old Aug 26, 2004 | 06:03 AM
Sbrut95's Avatar
Replaced HG's about 8k miles ago. So I hope thats not the case. Haven't noticed any coolant loss or anything so Im leaning towards something else. But you never know with these things.
Rasteirinho
Nov 6, 2017 03:40 AM
rocket
Jan 21, 2016 05:03 PM
Team420
Dec 30, 2015 01:31 PM
vanion2
Jul 29, 2015 06:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
