22re - where do these connect to?
Old Dec 28, 2004 | 09:37 PM
Brendan's Avatar
the plug end sitting on the throttle body and the other similar one just to the right a bit. i believe that the second one has never had a home but the first one does and i don't know where it is. no a/c in my truck if that matters...
Old Dec 28, 2004 | 10:59 PM
Yamaha+Toyota=Fun's Avatar
I dunno, i have those on my truck too. Maybe they accidently forgot it was a 4 and put 6 injector connecters. Your guess is as good as mine.
Old Dec 28, 2004 | 11:07 PM
Brendan's Avatar
hmmm, the black one has always been loose, but i never noticed the white one until recently. plus it's not wrapped together like the black one is.
Old Dec 29, 2004 | 12:02 AM
Joyota's Avatar
My truck has power brakes, power steering and A/C. No cruise or any other options. Here is the top of my engine. You can see the white connector in the circled area. I'll look tomorrow (Wednesday) for the dark connector.
Last edited by Joyota; Dec 29, 2004 at 12:03 AM. Reason: Forgot to attach pic (hey it's 4am)
Old Dec 29, 2004 | 09:46 AM
4Crawler's Avatar
Likely one is for the A/C idle-up VSV, it is a whiteish 2-pin connector on my '85:
Old Dec 29, 2004 | 09:54 AM
AKennedy87's Avatar
I think i used that white one when swapping my engine and I have no ac. Check near the coil to see if it stretches that wayor goes in anywhere around there. For some reason I have that going all the way across my engine bay and ontop of the engine and stuff. Bad placement
Old Dec 29, 2004 | 01:39 PM
Joyota's Avatar
Based on the color and location of the connectors, Roger is right. The white one goes to the A/C idle-up VSV (#4), which has a vacuum line running to (#5), highlighted with the yellow line. Numbers 1, 2 and 3 all go into the same harness, and #4 joins the harness further down the line.
I'm guessing your truck had A/C at one time, thus the extra white connector. I can't figure out where the dark connector goes, as my truck has A/C, PS and PB, and my brother's '89 4Runner has A/C, PB, and Cruise. I don't see the dark connector on either truck. Where does the opposite end of the connector tie into the harness?
Old Dec 29, 2004 | 01:41 PM
Joyota's Avatar
Roger, I think I screwed that one up. Which one is the A/C idle-up VSV, #4 or #5? What is the other one called? I knew what it's called, but I can't think of the name right now. I guess that happens when you're approaching 40. Brain fart...
Old Dec 29, 2004 | 05:58 PM
PirateFins's Avatar
Originally Posted by Jovis
Jovis / Roger anyone that might know.
In your pic there is a fitting on the back of the intake plenum, the last fitting on the right (towards the firewall). The one that is 2 fittings back from #1(cold start injector, in your pic). What is this fitting and what does it do? I broke off the black plastic cap/filter/vent (you can see it on top by the EGR)
and need to know if this is contibuting to my rough idle. Thanks
Ok I know this is off topic so I will look at my truck later to see what my connectors look like for you.
Old Dec 29, 2004 | 06:21 PM
4Crawler's Avatar
On my '85, the rear fitting is a 3-port, one hooks to the factory cruise control, one is plugged (I used that for my vacuum gauge) and the 3rd port feeds the fuel pressure regulator, via a VSV (they I removed - vac line direct to the FPR).
The purpose of the FPR line is to lower fuel pressure at idle and w/o the connection, the fuel pressure is too high at idle and you will get a rough idle because of that.
steve miller
Oct 10, 2015 01:40 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
