2001 with Clicking/Ticking Sound Underneath Hood...Engine Problems?!?!
Old Nov 14, 2007 | 04:55 AM
mkgarrison5's Avatar
Originally Posted by LSUMatt1514
Just got back from the dealer and running some errands. The service associate must have gotten his butt chewed because he was kissing my rear end today (and no charge for the diagnosis), even though I never got my return phone call from the associate service manager last week. Long story short, he said that it was coming from one of the valves on the driver's side. Said that it was most likely a lifter. He said that there would be no problem driving the truck like this and no risk of damaging the engine. He said it may go away just as quick as it showed up, which is what I'm hoping for. I'm not going to throw a bunch of money into this right now. I just added some SeaFoam to the crankcase to see if it will do anything with that lifter that is chattering. We'll see. But for now, I'm just going to ride this out.
He did recommend going from a 5W30 oil to a heavier weight such as 10W40. Service associate said that this may alleviate the problem itself. Mobil One does have a synthetic in this weight so I may give it a try at my next oil change. I'll keep you guys posted. Thanks for the help!!!!!!!!!
Matt
in alabama your warm to hot temps will allow you to use a heavier weight oil.. i use 10w30 (synthetic) most of the year instead of dead winter ill go to a 5w30 for better cold flowing properties.. i would NOT use a 10w40. maybe a 5w40 synthetic.. any over the counter oil will be fine in your truck. these 5z's are very easy on oil as long as you change your plugs, pcv, air filter and keep it in good tune. you can get 5k miles easy on a dino oils like Penzoil or GTX. i find my syns on sale like Advance autos buy one get one freen Valv. Synpower. the reason why he said go to a heavier oil is bc it will dampen the noise only. it wont "fix" the issue.. btw the ticking is pretty normal. either way dont go over 5k mile oci's without getting the oil tested by a lab bc our trucks and 4-runners have a piss poor airfiltration.. Mobil 1 is on the thin 30wt side for 5w and 10w30, so i would any other oil but M1 (that and its been getting iffy results back from labs) hence the reason why i just find my oil on sale and change it no more than every 5k miles. these are the oils i would recommend to you
10w30- (dino) Penzoil, GTX, Havoline, Maxlife
10w30- (synthetic) what ever is on sale, if no sales then buy dino
5w40 (synthetic only in this weight bc the synthetic has better flowing properties than dino in this weight.)
personally i would stick with 10w30 esp if your truck is under warranty
Old Nov 14, 2007 | 05:24 AM
Originally Posted by mt_goat
I had a ticking from the front of my 5VZFE that I just heard at idle. I was able to isolate it with this:
It was the bearing in the fan bracket. I replaced it and no more tick.
how did you isolate it to the fan bearing with the engine running?
Old Nov 14, 2007 | 05:38 AM
mt_goat's Avatar
It has a long probe and you just move it around until the ticking gets the loudest. It works great, $10-$12 at Napa, no tool box should be without one at that price. Of course, I wasn't 100% positive it was the fan bracket bearing but that's were I found the loudest ticking. And since this truck had been in a wreck and the radiator was pushed into the fan it was a likely point of concern. The fan bracket bearing housing doesn't move with the engine running if that's what has you stumped.
Old Nov 14, 2007 | 06:21 AM
what size tires are those? what year truck too.. thanks goat
Old Nov 14, 2007 | 07:03 AM
  #25
mt_goat's Avatar
I don't remember the tire size, its a 2001. I don't own it anymore, except for the engine and tranny.
Old Nov 14, 2007 | 07:48 AM
  #26
MTL_4runner's Avatar
The one in Dale's pic isn't assembled.....here it is complete.
Then just put the metal probe on various parts of the motor and when you're close to the problem you'll know right away.
Old Feb 11, 2008 | 06:27 PM
  #27
LSUMatt1514's Avatar
Just an update....It definitely seems to be coming from the engine. Borrowed a stethoscope and sure enough....driver's side. I switched to a 10W40 weight oil (Mobil SuperSyn) hoping that would help since two different dealers recommended I give this a try and to no avail. I've still got a ticking sound and I hate it!
Matt
Old Feb 11, 2008 | 06:30 PM
  #28
One other thing....I can also hear a clicking sound coming from somewhere in the rear of the truck. I guess it's an exhaust component that is loose or something. I can't hear it inside the cab...only when I get out to check the mail or something and the truck is in park. Next time I'm at a shop I'll have them crank it when it's on the lift and see if we can find it. Truck is starting to show it's age....2001 with 186k miles! Still runs like a champ though...although the gas mileage sucks even with super unleaded 93 octane. I'm sure my roof rack, brush guard, and 265/75/16 tires are not helping my gas mileage much.
Matt
Old Feb 11, 2008 | 06:33 PM
  #29
Sorry guys. I wanted to clarify something. I've been running Mobil Supersyn 5W30 since hitting 100k miles. I recently switched to 10W40 per the dealers' recommendations to try and stop the ticking sound. I didn't want you guys to get mis led and think I just now switched to synthetic.
Matt
Old Feb 11, 2008 | 07:25 PM
  #30
djlopaka's Avatar
possible problem
Had same problem on mine...I finally found out that it was the crankshaft pulley(harmonic balancer) the inner most pulley is bolted together to the outer 2 pulleys. The inner one has a rubber insulator which wears out and causes the pulley to separate. Hope this helps... I had crickets and sometimes grinding noises from in front of engine and couldn't diagnose until yesterday.. New inner pulley from Toyota about $280, from dorman about $130....
Old Feb 12, 2008 | 05:02 AM
  #31
Matt
yep thats the noise i have. the thicker oil quitens it down significantly BUT if you are under warranty only use 5w or 10w30 if you are not on warrantly then you can go with an 0w40 or 5w40 syn or dino. i wouldnt go higher... personally if you do not use syn go with valvoline maxlife 10w30 or the durablend 10w30 bc its in the heavy 30wt catagory or just keep using the 5w30 and live with the tick.. mine is the same as yours. seems like a toyota thing in these trucks..
Old Feb 12, 2008 | 05:04 AM
  #32
Matt
dont use 93 your truck wasnt designed to use a higher octane fuel. save the $ and buy 87 but from a well known station like texaco, BP and etc..
also if you are suing those uridium plugs then pull it and go back to the dual electrode plugs from denso or ngk.....
one more thing, M1 runs very thin, try switching brands in 5w40 or just get used to the ticking.. i have
Old Feb 12, 2008 | 05:06 AM
  #33
Matt
how long do you run M1 in one interval? if you are going over 6k miles on one oil change then bump it down and go to a higher weight.
Old Feb 12, 2008 | 01:16 PM
  #34
I run 5k between oil changes. What do you guys recommend I go with to help quiet the ticking sound?
Matt
Old Feb 12, 2008 | 06:35 PM
  #35
4rx's Avatar
4rx
maybe time for valve adjustments?
Old Feb 13, 2008 | 03:44 AM
  #36
Matt
if a thicker oil doesnt help then there isnt much you can do. just live with it or sell it. mine ticks too and you can really hear it using a thin 5w30 synthetic.. but after reading tons about this mess, ill just live with mine.
Old Feb 13, 2008 | 01:19 PM
  #37
I'm going to live with it until it's time to sell the truck, but I figure I'll drive it at least a couple more years until my wife's Sequoia is paid off. Then...time for a new Tundra!!! I don't want to sell it with this ticking noise (or the intermittent P0420 CEL) so the closer I get to time to sell...the more I'll invest in these repairs. Until then, I'm happy to live with them as long as they pose no threat of damage and from everything that I've gathered...neither issue does.
Matt
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
mengquis
Jul 13, 2015 10:39 AM
Johntom240
7
Jul 13, 2015 12:18 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
