2000 4Runner - Sunroof won't open / clear drain tubes
Old Aug 20, 2018 | 07:28 PM
maguirre's Avatar
Hi all,
I've noticed that my sunroof is been a bit leaky after a rainy day to the point where I have found my passenger side carpet a bit moist. I wanted to check it out this past weekend and clear the drain tubes that help flush water out when i realized that my sunroof was not opening (I press open button and nothing happens).
Is it possible that my leaky sunroof would cause the sunroof to malfunction and not open? Or is this a completely unrelated issue.
Please let me know where I should start looking to get my sunroof to open so that I can get to work on the drain tubes.
Tia,
maguirre
Old Aug 21, 2018 | 07:10 AM
akwheeler's Avatar
you need to start by checking fuses, if you don't find a blown fuse you will need a volt meter or at least a test light and see if there is power and ground to the switch, or to the motor when you press the switch. a wiring diagram might be needed as well.
AustinTaco
Jun 4, 2015 08:50 PM
ajmiata
Jun 14, 2014 05:27 AM
Puddleglum
Oct 22, 2009 08:59 AM
RS964WD
16
Sep 10, 2009 07:19 AM
jjenks0
Apr 21, 2006 07:24 PM
