2000 4runner chirps like a bird.. (noise,help)
Old Feb 13, 2012 | 05:35 PM
  #41
KU_MechE's Avatar
Originally Posted by BajaRunner
I had chirping only during deceleration...usually when I was coasting down hills.
I tried everything...
It ended up being my u-joints and driveshafts. Make sure you have them all lubed . There is a ton
Check out www.4runners.org and look for the driveshaft lube writeup.
QFT. Same here. Lube up all your driveshaft zerks and you should be fine
Old Feb 27, 2012 | 09:46 PM
  #42
robwise's Avatar
was your "chirp" loud and quick? i have such a chrip when i let off the gas and i was thinking it was a trany problem but it seems to be going into all the gears fine and the clutch is also engaging quite nicely
Old Feb 12, 2016 | 06:59 AM
  #43
PrinceGeorgeJr.'s Avatar
My 2000 4runner does the same thing. I'd really love to figure out what it is. It sounds like it's coming from directly underneath the driver seat.
Old Dec 16, 2016 | 06:27 PM
  #44
cado1966's Avatar
Same thing has been happening to my 2000 4runner over the past week. Squealing noise (like belts) only on deceleration. All zerks were pretty dry. Greased em up and the noise is gone! 😃
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
razorman8669
Jul 12, 2015 12:13 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
