2000 4runner chirps like a bird.. (noise,help)
#41
I had chirping only during deceleration...usually when I was coasting down hills.
I tried everything...
It ended up being my u-joints and driveshafts. Make sure you have them all lubed . There is a ton
Check out www.4runners.org and look for the driveshaft lube writeup.
#42
was your "chirp" loud and quick? i have such a chrip when i let off the gas and i was thinking it was a trany problem but it seems to be going into all the gears fine and the clutch is also engaging quite nicely
Jnkml
Jul 6, 2015 01:20 PM
