100 Octane???
#41
Free FMU mod hooked up. There was a hose already connected to that thing. it went to the line on the side of the TB area on the S/C iteself. I just capped that part off. Ohh and i somehow managed to kink the damn boost line :pat: ill have to order a new one off the net. It still works fine but thats going to be the first place it breaks at.
Should i reset the computer? Went to go fill up and it seems as is all the hesitation has gone away. Especially in third and as soon as i cross the 3k rpm mark she flies like no other. I dont know if its all in the head. but it seemed a bit better. Ill let you know what i get on the tank. This last tank i got 16.1mpg. well see how bad it drops.
I want to thank you for you helpful deeds
ill have to getcha a 12 pack or something.
#42
But hey, I am glad this helped you out.
#43
So then i dont need to reset the computer?? I know you were too busy scoldin me. lol. i know i shouldnt do it. buts its kinda hard to stop the erge against those damn rice burners. especially when they pull up to you revin ther pos's just because you have exhaust.
#44
Sure, reset the ECU. Pull the NEG then hold the brake down for 10 seconds.
I hear ya about those rice burners! I actually haven't ran into too many of them lately. They must be in hiding.
Just don't put a hole in your piston or fry a ring. If you do that Ford Asfire's will be smoking you.
#46
Those rice burners are all over the area i live. Live like 10 min away from Peoria where all the rich parents buy their kids w/e they want.
But, im thinking of removing this mod now.... I noticed when i let off the gas or go to switch gears, seems like its doing a reverse affect on the lean out condition. It almost sounds like its pinging when i do that. And at idle too. Only does it when it goes into the vacume stage. Either that or that valve is bad. I think im going to put it back the way i had it and just ease up on it or fill up with 100 octane.
And X2and4X Do it if you can afford both the S/C and the fuel upgrades. If you do you will wish you had done it sooner!
#48
Im getting a reverse affect from the free fmu mod. was wondering if you or know of anyone else here that had the same problem. Its pinging now at idle and when i go to switch gears. Only happens pretty much under vacume stage.
#52
#53
I agree about the clock and presets though; totally annoying.
#54
I used to do that too until I saw how long the ECU took to adjust with a scantool hooked up vs. the pull the NEG and step on the brake method. It was instantaneous using the NEG method, which is what I needed for tuning.
#55
Hrmmm.... I dico'd the negative cable. But didnt do the brake pedal thing. Whats that do might i ask?
Ohh and I Know i have it connected to the right thing. Because I only got 14.55 mpg this tank. And i filled up before and then did the mod on a full tank. :cry:
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
Oct 14, 2015 07:10 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
100, 2006, 4runner, arizona, bypass, douglasville, ga, magnuson, octane, rating, rattle, supercharger, supercharging, timing, valve
