yotarob2005's 1986 4Runner Build-Up Thread
#642
Had a little free time this weekend so I worked on pounding out some dents & ended up making a rough cut to remove the damaged sheet metal. It was a real PITA to get it off. I had to use some extra care that I didn't bother with when I cut the donor quarter panel off. Drilled out the spot welds & got it off cleanly though.
#644
Been super busy with work but I just had to try & get something done on my rig, so last night I did a little more cutting on the rear quarter panel. I think the hardest part of this job for me is making decisions on how to cut & weld everything back together. I started by making a rough cut on my donor quarter panel to make it a more manageable size, then worked on how and where to graft it to the truck. I ended up cutting some sheet metal back off of the support rail for the top of the bed, though it would be best to stagger the cut on the rail itself & the sheet metal. Turned out to be a pain but I got it fitting pretty damn good. Hard to explain so I will let the pics do the talking.
Bed
donor quarter panel
test fittting top veiw
test fitting rail from underneath
Donor panel sitting in place. Still need to cut out the underside of both to have it sit right.
Just need to decide where to make the final cuts, thinking about this.
Garage is a mess. I have a totaly new respect for people who do body work.
Bed
donor quarter panel
#649
Great job at summarizing! Really puts back into perspective, for me at least, just how much you've put into this thing.
Been wanting to ask you, ...Have the heims made a big difference in articulation/travel and taken some 'OUCHIE' off your BJ's?
Really love your truck, especially with those tires on there, man! Can't wait till you get her all sussed up and BACK OUT THERE! ...again, LOOKING GOOD! Any updates on the body work?
#650
hey man.....good job on the 1st post. lots of info right there.
just imagine if we all lived near each other......none of us would ever have money.....but the wives would always know where we were....my garage, your garage, Chef's garage etc etc etc. but i guess we will have to stick to our "virtual" hanging out in each other's garages......hahahahaha
#651
Anxious.......
Please, update, update! lol... Jk, I know, you're probably trying to find time... Been there, too! lol.
Can't wait to see her come back to 'TOIGHT LIKE A TOIGER!' STATUS!!!! lol
Mark
Mark
#652
I've been trying to figure out the best way to getting the new sheet metal on the 4runner, decided to quit worrying about it and bite the bullet. It was a real pain trying to get it to fit perfect. Seems like everytime I tried to trim one place to fit better, it threw it off somewhere else and with some of the sheet metal I was welding to already being tweaked, it was hard to line everything up. Not really happy with how it turned out, I'm hoping that I can still pound on it alittle. I will definatly be buying the large can on Bondo. It has gaps in places and the body lines are going to need some work.....but O'well at least it is on there. Body work sucks.
From a distance it doesn't look too bad.
Up close you can really see how big the gap is towards the top of the bed. At least an 1/8"
This is going to require some pounding to get flush, I think it is because of the old damaged metal not being strait.
By the time I got this far I had the hang of it & it came out pretty good. Guess I should have started at the bottom.
#655
Thanks guys, we will just have to wait & see what it looks like once I get it all welded & start adding body filler. It doesn't have to be perfect, I just find it hard to settle for less than perfect.
#656
! You'll get it, Rob, ..you're a resourceful dude! It's looking REALLY good, and HELLA BETTA than it was, ....I'm impressed! Mark
#658
My pleasure, homie....
BTW, did you use a level or something?(speaking of the part where the shell goes) Just curious how you decided "Ok, that's plum.... 'bzzzzzz' with the welder.... etc." hahaha.
