yota864x4's suprunner build up thread
#101
i have 12 feet of 2x4 square tubing them im going to be using, and i have a smittybilt tire carrier. well see how it goes!
#102
well i got bored and did a few things to the runner
i found some extra plates that were used to mount a toolbox at work, so i decided they would work awesome
i also finally found a can of navy blue spray paint that matches the runner good enough for what it is
and the hi lift has been bothering me, it was orange and rusty. sure bugged the heck out of me..
started mounting up the hi lift brackets
and now i dont have to worry about it flying forward and knocking me out
#105
i ordered myself some new rocker switches. these i got are from otrattw.com. very, very good company. they seem to have a good product and the customer service, seems to be top notch. i would gladly buy from them again
i also decided to try the spray paint and i painted the grill for the runner, looks a lot better in my opinion. not much a fan of black lol
#106
not really much into the whole fireworks things so i worked on the runner all weekend... got a few things done. got the caps on and welds ground down
finally pulled on the ol blocking kit from collision class
now i just have to wait for the doors to dry so i can get some chrome on them. i also got myself a full size chevy dana 44 with flat tops knuckles on both sides for a hundred bucks... now i got to cut it down and get the waggy shafts in it.
#109
so i finally got the half doors done, at least good enough so that i can run them. i love the doors. the airflow is awesome, maybe a little cold at 11 at night, cruising at 70 mph lol but the looks i get is priceless.
they looked funny with no chrome though, just looked naked and didnt fit in. so quick fix
i wanted to see what all the hype was about plasti dip, so today after work i bought some to play around with. heres what i started with...
and the finished product
i love this stuff, there i almost no need to really prep, dont have to scuff the surface. you just clean and spray on. if you dont like it then you just peel it off and theres chrome right there... its like witch craft or something lol
#110
Your half doors turned out sick, I want some SOoo bad! Maybe next year, too many projects, lol. Is that plasti dip pretty durable? I have some old aluminum Centerlines on my offroad trailer project that need to be black, and I hate prep work, lol.
#111
Idk... I've heard that is but also heard that it's not. A friend is going to run these on his Toyota so well see how they hold up and I'll report back
#112
Well it's been awhile, got a couple updates. Got a bikini top for the runner so I've been running it when it gets a little warm
Turns out that with half doors and a bikini top, it'll get a little wet inside when it rains. Runner looked good though, running the plasti dipped wheels on it
Also entered it in a local car show, sorry for the language, only pic I got
Got my new tires mounted up today. Well see how they do in the snow. I got a Toyota elocker waiting to go in it now.
#113
A little update, I have a list of things I need to get done before the snow comes. To start it, I was given a vice, and I had a old drop hitch that I acquired awhile back, it was pretty sketchy so I never wanted to use it for its real purpose. I decided to make a hitch mount vice for the runner...
I've also had as winch mounted, but it was never wired, I'm also needing a switch for engaging the elocker when it gets installed. So I came up with a replica 12voltguy switch panel
#114
Nice work on the vice! I had the same idea, I don't have a work bench and need somewhere to mount the vice from time to time when I need to use it. Now that I see how well yours turned out maybe I can get motivated!
I like your switch panel too, that's a good idea using the space where the ashtray goes, I'm already missing the ashtray, might have to steal your idea!
#115
I wad the same way! Never had the ashtray or bracketry since owning it lol I made it from a old license plate, I was going to paint it but I like the brushed aluminum look it has
#116
Been a while since I've been on here and I've been busy working on the runner. Well first off I got my elocker installed and wired up
I also got it 're geared with 488s, they seemed to help with the driving around town but I still wish the 7m had a little more low end torque
I used some shielded wire to help it look clean and came down through one of the drain plugs in the floor, I followed frame rail and brake lines getting it to the locker to try and blend in
While I was at it, I did a rear ubolt flip kit and 1.5 inch wheel spacers all the way around. I have no pics but I put a lock rite ratchet locker in the front of the runner, I had no idea that they were so loud!
Yesterday we finally found some snow and I got to test out all the goodies! I love the lockers, duals, and new tires. I should have done that a long time ago
#119
yea i have lol the motor is holding up decent. im on my second one and its starting to get a little tired. i think i got some tps problem going on being its idling funny now and feels extra weak. i think my next engine is probably going to be a supercharged chevy 4.3, only because of how cheap they are.
#120
So are you familiar with these engines at all? I don't know a whole lot about them but mines acting wonky... When it's cold out it has a surging/bouncing idle that I was thinking was a cold start injector. Well here recently it has felt like it has less power and that idle problem is happening when it's warm also... To the point where the idle drops so low when I shift or something that it dies or hesitates if I give it more gas... Any ideas?
