x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner
Old 12-11-2012, 09:17 AM
x250f23x's Avatar
And..
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-d.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-e.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-f.jpg
x250f23x's Avatar
And some more!
Hope this has been a good update for you.
The more people respond with feed back and comments the more it keeps me active in Yotatech.
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-g.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-34.jpg
Old 12-11-2012, 11:56 AM
Yopar's Avatar
Excellent...it looks great. Are you trying to keep the rig lower than normal, and that's why you had to raise the engine?
I need to read up on 3 link systems. I have seen 4WU's stuff around, but I am not that versed in links and need to check out some more builds.
Old 12-11-2012, 12:12 PM
x250f23x's Avatar
I wouldn't call it trying to keep the rig lower then normal, I would call it - I'm just greedy, and I wanted every last bit of up travel I could get. I want more up travel and down travel then leafs can provide.
As for reading up on links, this will bring you up to speed:
http://www.4wheelunderground.com/Suspension-411.html
Old 12-12-2012, 09:27 AM
  #25
x250f23x's Avatar
With the motor mount...
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-assembly.jpg
Old 12-12-2012, 09:37 AM
  #26
Yopar's Avatar
Looking forward to seeing the T-case mount installed,...I'm guessing you'll fab some extensions from the street mount > to the frame.
Thanks for that 4WU article.
Old 12-12-2012, 10:46 AM
  #27
x250f23x's Avatar
Yes, some 2x2 .120 square tube will be used to connect this all to the frame, Same for the motor mount perches. Just got word this morning it has been cut and awaiting bending, so I should have this before the end of the week.
Stay tuned!
Old 12-13-2012, 10:10 AM
  #28
x250f23x's Avatar
And it's here!
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-35.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-36.jpg
Old 12-14-2012, 12:19 AM
  #29
x250f23x's Avatar
Welded and bolted, getting longer hardware today
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-37.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-38.jpg
Old 12-17-2012, 11:50 PM
  #30
x250f23x's Avatar
Motor mount perches made and tac'd in
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-39a.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-40a.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-41a.jpg
Old 12-18-2012, 07:41 AM
  #31
Yopar's Avatar
I like it! Simple and clean.
Old 12-19-2012, 10:55 PM
  #32
x250f23x's Avatar
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-47a.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-48a.jpg   x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-49a.jpg
Old 03-05-2013, 06:03 AM
  #33
RBX
RBX's Avatar
Just got my kit!
Your T-case is really nice, I like it.
Old 03-05-2013, 08:35 PM
  #34
x250f23x's Avatar
Originally Posted by RBX
Just got my kit!
Nice! Welcome to the family.
PM me if you'd like a T-case mount like it. We'll get you set up nice.
Attached Thumbnails x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner-x250f23x-_-71.jpg
MMA_Alex
25
04-18-2017 05:07 AM
Gone Fission
07-24-2015 12:49 PM
colasurdo
07-18-2015 07:06 AM
colasurdo
07-16-2015 11:32 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: x250f23x _ 1990 pick-up X-cab 2WD frame _ KOH pre-runner
