wberry85 1991 Pickup build
Old Sep 7, 2015 | 08:37 AM
  #101
desert_vet's Avatar
Originally Posted by desert_vet
That truck looks really good. I dig the side rails and doors, freakin' awesome. Parts equal lighter wallet Have fun be safe, don't over do the liquid refreshments. Need a front brush guard?
Sorry, did not see last pics. Your brush guard is really cool. Could you post a ballpark figure of cost of the work so far? Enjoy the trails . Keep up the great job. It will be a terrific ride after the mods are done, looks super now.
Old Sep 8, 2015 | 03:47 AM
  #102
wberry85's Avatar
Thanks man. I lost count long ago on how much I have into it. I would guess around $7k. If I knew then what I know now I could do it much cheaper the second time around.
Old Sep 9, 2015 | 04:56 AM
  #103
desert_vet's Avatar
Yes, the learning curve always has a higher price. Yet, the experience hopefully will produce a better return on time/money invested. Yota looks real good. I have some pics of some friends rigs & items we made for them. I get them uploaded soon. Happy Trails.
Old Sep 15, 2015 | 07:50 AM
  #104
wberry85's Avatar
Next step is modifying the trail gear bumper to fit with my bed bob. A quick test fit even with drilling new holes in the frame shows the bumper will stick out about 5" too far. So time to cut!
I had to cut 3" out of the mounting plates to bring the whole bumper closer to the truck. This will reduce the gap between the tail gate and the bumper by 3" and leave a 2" gap (the same as the gap on the sides where it wraps around the bed). I hated to have to cut this plate as it creates a possible weak point in the steel but the bumper just stuck out way too far from the bed.
I also had to take 6" out of the side guards so they would not protrude into my wheel wells. A lot of cutting points but it all went back together nicely. I took as many pics as I could for yall as I am the first one to attempt this as far as I know. I really like the TG bumper and it was useless after the bed bob so I had nothing to lose here by hacking it all up. Its just tacked up right now for a test fit.
Old Sep 15, 2015 | 07:57 AM
  #105
bump530's Avatar
Are you going to plate the weld area or add any bracing?
Old Sep 15, 2015 | 08:06 AM
  #106
wberry85's Avatar
On the frame you mean? I'm going to use bolts to attach it. No plans for plating yet. I would like to but the bumper fits very tightly on the outside of the frame rails and its going to be a real bitch if I have to fit another 1/4" of steel between the two mounting plates (might have changed since i cut it up). I thought about at least welding in some bolt sleeves through the frame where the bumper attaches.
I have thought about a stronger crossmember on the end of the frame rails where I cut them off but Im not sure if that will do nything for the bumper.
Old Sep 15, 2015 | 08:49 AM
  #107
bump530's Avatar
No I mean where you cut the bumper mounts and shortened them up.
Old Sep 15, 2015 | 12:15 PM
  #108
wberry85's Avatar
It fits!
Cant even tell it was cut. The wonders of a sanding disc...
Bump I made a plate for the mounting bracket out of some 1/4" plate. Post pics in a sec. Good call!
Old Sep 15, 2015 | 12:56 PM
  #109
wberry85's Avatar
Here are some pics of the plate I used to beef up the mounts. Burned it in on the highest setting so hopefully the penetration is good and everything is sturdy. The welds laid flat so I think its pretty good. Ill yank on it a couple times and test.
Old Sep 15, 2015 | 01:42 PM
  #110
bump530's Avatar
Looks good. I'm ready to get to the bumper building phase of my ride.
Old Sep 17, 2015 | 03:32 AM
  #111
wberry85's Avatar
Flat tires scare me. I dont carry one on any of my trucks and I need to. But how to carry it?
Found this awesome design on another forum. I plan on making it this weekend. I love the angled design and the fact that you can flip it up and have the tire lay flat if needed so you can fit stuff underneath it for camping etc.
I have some 1.5" tube laying around I can use. Its only .065 wall so I hope its sturdy enough but we will see.
Old Sep 19, 2015 | 03:47 PM
  #112
wberry85's Avatar
Wow lots of stuff to update.
New gas tank installed...check!
Spring hangers moved and shackle angle fixed...check!
Bumper shortened and reattached...check!
Finally back on the road.
And the pics of course.
Old Sep 19, 2015 | 03:49 PM
  #113
wberry85's Avatar
Oh yeah...driveshaft finally came in from Davez. A full foot of travel and very heavy duty. I'll be be attempting to redrill my flange and install it tomorrow.
Old Sep 19, 2015 | 04:08 PM
  #114
Back to the Future's Avatar
Lookin good bro!
Old Sep 22, 2015 | 04:27 AM
  #115
RoBatt's Avatar
What an awesome Build! Im in the very early stages of my SAS (just been acquiring parts) I have a couple questions.
As someone who also feels like they have read every SAS thread online - why did you go with 3 inch springs? I have read that 4 inch springs ride better and they drop more once they are broken in.
Did you have to modify your rear driveshaft at all or does it have enough travel?
Old Sep 22, 2015 | 04:41 AM
  #116
wberry85's Avatar
I went with the 3" because I wanted to keep the build as low as possible and just trim fenders if I need more travel. I wanted to keep the lowest center of gravity possible. I knew I would be running 35's and the 3" springs fit the 35's the best. Even with the 3" springs the truck sits tall!
My rear DS is stock and no issues with it coming loose.
Old Sep 28, 2015 | 11:02 AM
  #117
wberry85's Avatar
Sooo this happened today!
Old Sep 28, 2015 | 12:53 PM
  #118
bump530's Avatar
seems like a good reason to put a 4.3 in it lol
Old Sep 29, 2015 | 03:45 AM
  #119
wberry85's Avatar
It got pretty hot til I could pull over and all I was thinking was man if I blew the head gasket it will be a great excuse to do a motor swap!
Old Sep 29, 2015 | 04:41 AM
  #120
bump530's Avatar
What would you swap in?
