Swimmerboy2112's 1986 4Runner Build-Up Thread
Old May 1, 2011 | 07:39 PM
  #2561
Swimmerboy2112's Avatar
Originally Posted by irab88
sweet. can't wait for dem pics
Soon my friend! I plan on painting (or powdercoating) the calipers red, not sure wether or not to paint or powdercoat.
Old May 1, 2011 | 08:43 PM
  #2562
Bought this
http://cgi.ebay.com/1-HP-2-Gal-12-Vo...8#ht_525wt_907
Old May 2, 2011 | 03:47 AM
  #2563
RBX's Avatar
RBX
where are you mounting it.
i was going to get the smaller 1 gallon, and mount the tank under the truck and the compressor inside the bed wall.
Old May 2, 2011 | 04:55 AM
  #2564
irab88's Avatar
ooh! oba ftw
Old May 2, 2011 | 05:42 AM
  #2565
xxxtreme22r's Avatar
oh yeah I forgot about my HF one that is similar to that. There is no way in heck I am gonna be able to run mine from my truck. That's too much current to run. That thing looks pretty cool though.
Old May 2, 2011 | 06:30 AM
  #2566
irab88's Avatar
time for a gm alt upgrade, then?
Old May 2, 2011 | 06:33 AM
  #2567
I'd still need like a 1500-2000W inverter plus the alt
Old May 2, 2011 | 06:40 AM
  #2568
irab88's Avatar
naw, his is 12-volt, not 120 ac
Old May 2, 2011 | 06:42 AM
  #2569
yeah i know it seems like a nice little unit.
Old May 2, 2011 | 06:59 AM
  #2570
irab88's Avatar
3.4 cfm is impressive. top-of-the-line viair compressors don't even match that
Old May 2, 2011 | 08:43 AM
  #2571
ChefYota4x4's Avatar
On board air? ..... Trying to remember if the plans for this one were going there... or if the gears he's gonna put in already have one in em....... Oh well, I'll just stay tuned in, hahaha.
Nice find! ...>I think, hahaha.
Old May 2, 2011 | 01:34 PM
  #2572
Not sure where i'm going to mount it. I wouldn't mount it inside the bed wall, it needs to stay cool, constricting it that much, you run the risk of overheating it. And i wouldn't put the tank under the truck, one little rock and you're outta luck. I know when i do mount it, i am going to put little rubber feet under it so it absorbs shock.
ooh! oba ftw
YES!
Ah that's a shame.
Yeah ToyoTech559 has the slightly smaller version and he LOVES his aside the small size so i figure I'd grab the bigger one! He helped me figure out which one to grab. This one is better than the ARB one, its more powerful, pulls less amps and has a 100% duty cycle at a higher PSI!
Yeah i was really impressed and it got great reviews!
Haha I'd love to do an ARB air locker but i can't seem to find a good deal on one... yet....
Old May 2, 2011 | 02:24 PM
  #2573
RBX's Avatar
RBX
Yukon zip locker is cheaper, same idea as arb.
Engine heat kills compressors, but I was thinking I would use some of my perforated aluminum for ventation.
I think the tank underthe truck is doable, with skid plate or thought out location. They are steel tanks.....right?
Old May 2, 2011 | 02:37 PM
  #2574
I'll look into the Yukon, thanks RB!
I forgot you had that perforated alum. I'd still keep a close eye on it to make sure she's staying cool? Maybe wire in a 12V fan?? You know like a little fan they put in welders and such.
The tank underneath is doable if you tuck it up inside the frame, make sure its the last thing to get hit if you bottom out.
Old May 2, 2011 | 04:38 PM
  #2575
Oh i forgot to mention, swapped in the new built driveshaft, no more vibration
Old May 2, 2011 | 08:41 PM
  #2576
irab88's Avatar
where in the engine bay would you mount the compressor?
Old May 3, 2011 | 02:17 AM
  #2577
I wouldn't. It gets too hot in there and there isn't tons of space. Not to mention the front is the most likely place to get hit in a crash.
Old May 3, 2011 | 03:41 AM
  #2578
RBX's Avatar
RBX
^^^^ what he said
Old May 3, 2011 | 04:44 AM
  #2579
irab88's Avatar
so just a set of clips or high-amperage plugs? or mounted somewhere else?
Old May 3, 2011 | 05:47 AM
  #2580
RBX's Avatar
RBX
My plan is to connect it directly to the battery, after a circuit breaker then fuse, so i can activate it with a switch, and make it easier to tie an air-locking-diff into later.
I already have the power run to my OBA location in the rear.
